bulbul
posted on 24/2/04 at 06:28 AM |
ignition system
I am currently building a westfield SDV and need to remove the engine fron the sieera, my question is , do i need to keep the ECU and the other fuel
injection stuff from the pinto or can I buy an aftermarket kit to do the ignition timing.I will be using Twin 40 webbers
Julian B
| posted on 24/2/04 at 08:38 AM |
Hi
I would remove the lot. Label it as you remove it from the Sierra otherwise its a bit of a job working out what went where six months down the line.
You may find this link useful as it explains ways around these problems.
http://community.rhocar.org/index.php?showtopic=377&st=0&#ent
ry1784
Also don’t forget to remove the ignition amplifier module from the Sierra ( if it has one its normally bolted to the front inner wing )
Also if you have the injection head remember to specifically get the injection inlet manifold gasket. The injection head has bigger inlet ports. If
you try to use the standard gasket you can end up with air leaks!
Good luck
bulbul
| posted on 24/2/04 at 11:23 AM |
Thanx julian,
Where can I get an injection head to twin 40's carbs manifold gasket and other goodies, as I'm new to this game, I end up going to
halfords and thats expensive!!!
chrisg
| posted on 24/2/04 at 06:30 PM |
quote: Originally posted by bulbul
I end up going to halfords and thats expensive!!!
Is it?
Compared to buying a Westfield?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Julian B
| posted on 24/2/04 at 09:00 PM |
The gasket is available at your local Ford dealer. Just make sure it is the injection one...
Have a word with your local Webber rep/dealer when it comes to the inlet manifold. Dont forget they come in different lengths so get the right one.
Halfords are OK but as you say they are hellish expensive. Try Partco or TMS as they supply the trade as well as Joe public. I have found that they
are always willing to help providing you tell them what you are trying to do..
Stu16v
| posted on 24/2/04 at 10:21 PM |
Welcome Bulbul, may I introduce to Chris, the resident pisstaker (well, one of them)?
I would advise talking to Burton Power, or another Ford specialist with reference to the manifold. Some pinto-to-weber manifolds may not fit the
injection head correctly due to the cutouts in the ports for the injectors....
And have a look here, the Westfield club forum. Plenty of folk on there going
through the 'fun' that is an SDV build....
Cheers, Stu.
bulbul
| posted on 25/2/04 at 04:58 PM |
Once again, thanx julian and also thanx stu for the gen on manifolds and notifying me that chris is a joker( I can call off the hit)
