daryl
| posted on 2/9/10 at 11:39 PM |
wiring problems
hi there well a was out the other sunday car runing grate then it just came 2 a stop as if it had no fuel in the ignition worked and lights and so on
worked the push bottom start would not work or light up a fuse had gone so replaced that still no joy to start so put a lil fuel in top of carbs it
would fire then so checked fuel pump it was not pumping so replaced with new 1 it wont work on car but if a put a live and poss to it the pump works
and more ideas wot 2 check its on a 99 r1 engine it just makes like a clicking noise
YQUSTA
| posted on 2/9/10 at 11:56 PM |
Have you checked for voltage from the feed to the pump?
If it is at fault it may also be fused or could be a broken cable.
If you have voltage then check the earth.
"If in doubt flat out"
Colin McRae
interestedparty
| posted on 3/9/10 at 05:19 AM |
Agreee.
And if there is no voltage, is there any kind of safety interlock to stop the fuel pump if the bike goes on it's side etc?
adithorp
| posted on 3/9/10 at 06:49 AM |
So it came to a "full stop"?
Not sure whether the carbed R1 has a tilt switch but that could be it. Then time to get the wiring diagram and multimeter out. Fuses and start relay
are possible causes as is a loose connection between the bike loom and the extentions to the car.
adrian
http://jpsc.org.uk/forum/
daryl
| posted on 3/9/10 at 02:00 PM |
well a will check both just 2 rule out a problem do you know if the r1 has a fuel pump relay or not just its my m8 thats been looking at it 4 me as
well and a cant seam 2 c a relay or is it just in the ecu sorts all that side of fueling out
