Tinbasher
| posted on 20/10/22 at 07:12 PM |
Cooling fan temperature 1.6 CVH
Hi can anyone help I have overheating issues on my 1.6 CVH, I think
The fan switch fitted is too high at on at 100 off at 95 degrees C.
Does anyone know what temp the fan should cut in
Dave
Dave Lindley-Adsett
adithorp
| posted on 21/10/22 at 01:15 PM |
When foes it overheat? When stationary/ticking over would indicate a possible fan/sensor issue. If when driving and it's a cooling issue as the
fan shouldn't be needed.
A quick look in an old catalog shows 1.6cvh escorts having an intermotor 50013 or 50014 switch. They're both 103c/98c on/off.
[Edited on 22/10/22 by adithorp]
http://jpsc.org.uk/forum/
Tinbasher
| posted on 22/10/22 at 02:01 PM |
Hi it overheats when still it must be a fan sensor as it won’t cut in but the fan works if fan switch is bypassed
Dave Lindley-Adsett
adithorp
| posted on 23/10/22 at 08:12 AM |
I'd change it then.
Are you using the original sensor/position or something different? Around 95-105-ish switching is quite normal if the sensor is on the engine (as
I'd expect from the spec' I found). On the rad it's more likely to be 85-95-ish range.
There's a list of Intermotor sensor parts numbers/thread size/switching temps here...
https://fuddymuckers.co.uk/wiki/doku.php?id=electricals:intermotor_fan_switches
I've used a twin temp switching sensor in the past when I wasn't sure which to go for and then tried both circuits to see which was best.
Tinbasher
| posted on 23/10/22 at 10:40 AM |
OK thanks I will give that a try
Dave Lindley-Adsett
