john_p_b
posted on 8/4/05 at 06:12 PM |
how does my speedo sensor work?!
ok random one here but as title, it came with the gauges but the instructions are as vague as they come.
it's a vdo gauge set so obviously a VDO sensor, it's about 3" or 4" in length 3/4" in diameter with some thread near the
top of it and 2 terminals on the top of it (one smaller than the other).
would have put a picture up to save that explaination but camera is dead!
anyone used one of these? how does it work? what does it pick up? magnet etc? really am a little stuck with this!
thanks in advance for all your wonderfull help
thanks
john
RogerM
| posted on 8/4/05 at 06:22 PM |
Sounds like a hall effect sender. Depending on spec you will need either 1 or a number of magnets stuck to the prop or diff flange.
Doesn't VDO have a website???
john_p_b
| posted on 8/4/05 at 06:30 PM |
vdo website
yeah they do have a website but to say the least it's next to useless, lists the guages but nothing about senders for them
givemethebighammer
| posted on 8/4/05 at 07:19 PM |
I bought my VDO gauges from lowtension:
http://www.lowtension.com
very helpful people. I used the univeral sensor with magnets glued around one of my driveshaft flanges, rather than the hall effect one.
fitting instructions here:
http://www.lowtension.com/pdf/performance_%20kit.pdf
carlgeldard
| posted on 8/4/05 at 08:02 PM |
I posted this about a week ago.
http://www.locostbuilders.co.uk/viewthread.php?tid=24127
I think you have got a inductive sensor I hope this works for you. I know what you mean about the instruction and the speedo
Carl
ReMan
| posted on 8/4/05 at 10:09 PM |
thanks
john
If you really mean How does it work , then does it matter as long as it does, if paired with your clocks it probably will?
Or is there another sublime question, like why does it work?
In which case, thats science!
| posted on 8/4/05 at 10:58 PM |
Have faith.
It will only work if you really believe in it unlike my bl**dy starter motor the other day
john_p_b
| posted on 9/4/05 at 09:59 AM |
well after mucho internet searching i've concluded it's a inductive sensor and requires 4 magents to work. only issue now is where do i
get 4 identical magnets!
flange nut
| posted on 9/4/05 at 10:08 AM |
Try Ebay for the magnets. There are normally lots for sale, for example.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=1267&item=7506401887&rd=1
clbarclay
| posted on 9/4/05 at 10:02 PM |
Companys like RS componts sell a wide range of magnets.
Also try
http://cpc.farnell.com/jsp/endecaSearch/searchPage2.jsp?OrgTT=magnet&Nty=1&N=1000085+401&=gensearch&No=0&Ntt=magnet&Ntk=gensea
rch&comSearch=true
[Edited on 9/4/05 by clbarclay]
