Author: Subject: loom - needs to have outer covering?
posted on 17/2/06 at 08:40 AM Reply With Quote
Does the wiring loom need (for SVA) to have an outer covering - split convoluted or sprial wrap tubing - wrapped around it?
i.e. is it ok just to wrap it up with insulation tape?
posted on 17/2/06 at 08:44 AM Reply With Quote
The testers won't accept insulation tape.
They may accept proper loom tape (the non-sticky stuff) if you manage to do a really tidy job.
I wouldn't use spiral wrap, except for very short lengths - I used it for everything, but it was a tedious job and it makes later modification a real PITA.
If I was doing it again (or when I next make any mods) I would use split convoluted tube - it's fairly cheap, quick to install, does an effective job of protecting the wiring and looks neat. Get a few sizes so that you can use the right size for each part of the loom.
cheers,
[Edited on 17/2/06 by David Jenkins]
RazMan
posted on 17/2/06 at 08:54 AM Reply With Quote
I have used heat shrink tubing where possible - it makes a good protection coating for areas which get dirty easily and stops water getting in cable connections (in wheel arches for example)
Everything else has split convoluted tube. This ensures that you can add that forgotten wire easily (spiral wrap is a pain)
[Edited on 17-2-06 by RazMan]
Raz
posted on 17/2/06 at 08:55 AM Reply With Quote
My Vikki Green loom was already wrapped in non-sticky loom tape. Where I have made additions and extensions to the loom I have wrapped them in the same non-sticky loom tape. The whole lot is then sheathed in split convuluted tubing of various diameters and secured to the chassis with rubber cushioned metal P clips or cable ties.
I've use Vehicle Wiring Products for all the electrical bits I've needed. Excellent range of products kept in stock, helpful people and quick delivery.
HTH
Nick
posted on 17/2/06 at 08:58 AM Reply With Quote
thaks for quick response;
convoluted tape it is then.
how through are the examiners?
will they want me to remove the nose cone?
The 2 sections of loom are:
1. indicators in nose cone; this will be held in place with resin to hold p-clips or other type of clips
2. headlamp wiring - routed across a chassis strut, held on by cable ties.
donut
posted on 17/2/06 at 09:01 AM Reply With Quote
If you use insulating tape it will look really kak! Best to go with what peeps on here suggest, after all you don't want to fail on the wiring and have to rip it all out as that would be a nightmare!!
smart51
posted on 17/2/06 at 09:06 AM Reply With Quote
My wiring loom was supplied in a split tube with sticky insulation tape around the joins. I modded the loom somewhat and used insulation tape around the new bits. The bike loom in the engine bay also used some insulation tape. I made a sub loom for the instruments under the dash and used insulation tape. Mr SVA inspected them all thoroughly and made no comments at all.
bimbleuk
posted on 17/2/06 at 09:09 AM Reply With Quote
RE: Inspection
If it looks like it was designed to be removed easily then they will very likely ask you to do so. For example vinyl covers held on with poppers and access panels with simple screw fixings (like my pedal box lid).
So if your nose cone was bolted on then unlikely to be romved. Just remember this, if they can't see it then they can't test it! The underside of my dashboard is completely panelled which stopped them laughing at my wiring
[Edited on 17/2/06 by bimbleuk]
posted on 17/2/06 at 09:17 AM Reply With Quote
My nose cone is held on with 4 Dzus fasteners, and I wasn't asked to remove it - I'd guess that he could see enough from above and below to satisfy his curiosity (he did do a LOT of the inspection from below).
