graememk
| posted on 17/9/06 at 08:04 PM |
lights
ok wiring up the dash and finishing off the loom now i have all bits i needed from donnington.
my headlights have seperate bulbs for dip and beam, would it be ok to leave the dip on when i turn on beam, relays and switches all up to the job.
sva and mot ok or not
RazMan
| posted on 17/9/06 at 09:13 PM |
IIRC it is ok to have dip remain on when main is on - many cars are wired this way.
Raz
| posted on 17/9/06 at 09:31 PM |
are you sure there? Most cars ive had leave dip on for flashing but not with perminant full beam. That might just be to save bulb life, but it rings a
bell somewhere...
MkIndy7
| posted on 17/9/06 at 09:40 PM |
Would put extra strain on the Earth wire as I think they share the same.
omega 24 v6
| posted on 17/9/06 at 09:46 PM |
Yes it would you'd need an earth wire capable of handling around 10 amps per side continuous for a 55/60 watt dip/full beam bulb. Also there
could be a heat problem with 2 filaments burning especially if it's in a plastic case.
RazMan
| posted on 17/9/06 at 10:37 PM |
quote: Originally posted by graememk
my headlights have seperate bulbs for dip and beam, ........... relays and switches all up to the job.
I think he's got that covered
Raz
graememk
| posted on 18/9/06 at 07:31 AM |
there is 3x earth, dip beam and indicator, i just wondered about if both could be on for sva/mot, just means i'll see more when its dark
| posted on 18/9/06 at 09:02 AM |
IIRC the SVA manual states that in a single casing which houses main and mip beam - dip must extinguish when main beam is active unless on a
'flash' control. Most bike wiring uses a common earth from the casing and IMHO would be unnecessary as the beam patterns are different.
This combined with the extra heat generated from effectively having two bulbs per casing illuminated for no significant gain is unwise IMO.
My 2p - Steve
graememk
| posted on 18/9/06 at 09:36 AM |
bacause i'm sad and have to much time on my hands i've just checked my own car and both bulbs are lit when you turn on beam
graememk
| posted on 19/9/06 at 04:55 PM |
spoken to martin at nots sva who had a quick chat with someone else and came back with yes from what you are telling me (or words to that efect) that
will be fine wired up like that
