Author: Subject: speedo magnet attached to drive flange?
posted on 29/1/07 at 10:58 AM Reply With Quote
escort english axle on rear; Iim thinking of attaching a magent for a bike speedo sensor inside the drum, i.e. to the drive flange.
good idea or not?
Otherwise how else do I attach it so it doesn't fly off? (have steel wheels if that makes a difference)
daviep
posted on 29/1/07 at 11:13 AM Reply With Quote
Placing the pick up on a wheel means your speedo reading will be affected by corners.
I was going to try and take mine off the crown wheel. Don't know how mag pickups are affected running in oil ?
stevec
Cant you put it on the pinion shaft or Propshaft? I think in the drum is a bit of a hostile environment.
Steve.
posted on 29/1/07 at 11:18 AM Reply With Quote
re: corners - not too worried about that as it will be tesed on the rollers at SVA (it is back up in case I do not complete my motor driven speedo in time).
re: prop, the wheels size would need to be 1/4 to give correct speed - I donlt think bike speedos cater for 7 inc dia. wheels
wher have other folks mounted theirs?
Danozeman
posted on 29/1/07 at 11:46 AM Reply With Quote
Mines stuck to my diff flange with pickup mounted on a braket on the diff casing.
Dan
davrus
posted on 29/1/07 at 01:11 PM Reply With Quote
I have fitted mine to the drive flange inside the drum, Not tried it on the road yet but i can not see it being a problem, just means when you wheel spin it will read higher but normal driving should be ok, not going to be doing lots of miles to get covered in brake dust so a quick clean out every now and then will do me just fine.
Take care.
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
tks
posted on 29/1/07 at 03:50 PM Reply With Quote
go inductive
and use the diff bolts etc..
Tks
mark chandler
posted on 29/1/07 at 04:13 PM Reply With Quote
Just to add a bit of fuel to the fire, I spent the weekend playing around with my RRV blade clocks as I do not want to buy a speedo healer.
185/60/13 wheels with a 3.62 diff require 9 magnets on the prop, using an ABS sensor as the pickup wired to earth
So I would look at mounting magnets on the pinion, get the number of magnets right and save a few quid.
nb/ this related to around 36 magnets if I had hung them on the halfshaft/wheel.
Regards Mark
[Edited on 29/1/07 by mark chandler]
PeterW
posted on 30/1/07 at 08:54 AM Reply With Quote
Mate used 2 p'clips with cylindrical magnets in them, bolted under the heads of 2 prop bolts. They are still fine, and work very well. The p clip stops the magnet flying out, and for added safety they are epoxied in also.
Peter
