<<  1    2  >>
Author: Subject: Handbrake and Horn
posted on 13/8/05 at 08:13 AM Reply With Quote
you can have the switch in the earth side or the live side, it makes no difference! Petes diagram is excellent, and it is indeed showing earth switching.
Benzine
posted on 13/8/05 at 08:59 AM Reply With Quote
Just wanna clear something up. The digidash has it's own earth supply. If the live wire is taken straight to the bulb it will always light up regardless of anything else. If I were able to switch the live wire then I could get it all working. I can't use the handbrake to control the live wire as it's earthed and just causes sparks. Can I use a small switch in someway to test the M/C from the drivers seat? As that wouldn't be earthed, I can run a live to it.
I don't know what I'm doing wrong. Surely someone must have used a digidash before, I'd just like to know how they've wired up the handbrake.
R.I.P another fuse (I now have a pile of about 20 dead ones )
[Edited on 13/8/05 by Benzine]
posted on 13/8/05 at 01:04 PM Reply With Quote
Sorry, i didnt know the digidash had its own earth that sort of stuffs up the switched earth plan!
So you need switches in the live side of it all. Assuming its not LED lights, you could probably just reverse everything in petes diagram.
Benzine
posted on 13/8/05 at 01:46 PM Reply With Quote
They're LEDs
Is the test switch used purely to test the bulb in the dash? If so I can wire a switch in which would be simple. Thus:
The switch would work in the same way as the switch at the M/C and the blub would light. It could be dash mounted and used to test the bulb. Is that okay?
posted on 13/8/05 at 01:58 PM Reply With Quote
cant seem to post a picture... gimme 2 mins to try!
but yep, you're correct.
[Edited on 13/8/05 by JoelP]
posted on 13/8/05 at 02:00 PM Reply With Quote
posted on 13/8/05 at 02:01 PM Reply With Quote
Benzine
posted on 13/8/05 at 03:41 PM Reply With Quote
Thanks for the diagrams...blew another fuse though
My button switch is wired up and when pressed, the dash light comes on. Is this okay or is it the actual M/C plug circuit that needs to be tested? If it's just the bulb in the dash then I can put this to rest
posted on 13/8/05 at 05:02 PM Reply With Quote
i think its just the bulb you need to test, but after my previous wrong advice it might be best to wait for confirmation!
<<  1    2  >>
