COREdevelopments
| posted on 14/4/08 at 08:38 PM |
i think it is now comunicting with the magajolt as when i am on the new version and switch on the ignition a warning box appears saying that i have
an unsupported controller version. i have downloaded it but cant get it to open as it does not recognise the program that created it. so i am gettin
somewhere but then getting knocked back!
lsdweb
| posted on 14/4/08 at 08:39 PM |
Rob
You can borrow my old laptop, with serial port, if you want to try it - I'll need it back pretty quickly though as I'm in the middle of
setting up my ECU and I haven't chanced a USB converter with my Emerald!
Wyn
paulf
| posted on 14/4/08 at 08:40 PM |
Restart the pc after changing the comm port or it wont be active on that port, can you select comm 7 on the megajolt menu?
Paul
quote: Originally posted by COREdevelopments
nothing is being used on com port 7 so i am using that. i have dowloaded the latest version but cant update the cntroller firmware. i have not got use
to an old laptop. but may have to buy one by the looks of it.
thanks
rob
paulf
| posted on 14/4/08 at 08:45 PM |
Try downloading config version 3.00 it is an older version and should work with the firmware in the unit.
Paul
RichardK
| posted on 14/4/08 at 08:57 PM |
Sounds like you're nearly there fella, what he says above use version 3 and get it working then when you can upgrade to the latest firmware and
then start using the latest software version to reconfigure, not exactly sure what's the difference between the firmwares anyway.
Keep going mate you get it sorted soon.
Rich
Gallery updated 11/01/2011
COREdevelopments
| posted on 14/4/08 at 09:00 PM |
thanks wyn, its ok i will try and get this sorted out, wont let it beat me.
COREdevelopments
| posted on 14/4/08 at 09:06 PM |
PAUL you are BLOODY legend!!!!
got it to communicate on v3.0.0.
ooooooo what a relief!!! is it too late to start the car up?? i think not!!!!
cheers guys for all your help especially paul.
thanks
rob
RichardK
| posted on 14/4/08 at 09:07 PM |
Nice
paulf
| posted on 14/4/08 at 09:31 PM |
Thats good to hear , V3.0 will work fine but have a look on the web site to see the improvements with V3.2.1 and then let me know if you need any help
to upgrade the firmware.The maps you were having trouble opening should now open ok with V3.0
Paul
DarrenW
| posted on 15/4/08 at 01:53 PM |
Ive just reda this thread. Sorry im a bit late. I too had big problems with MJLJ. Solved when Brent advised to upgrade my PC software as you have
done. I also found brays terminal was very handy when checking out the com ports to make sure they were matched. Im sure i posted a link ages ago -
need to do a search for it.
