welderman
| posted on 13/11/08 at 09:09 AM |
2003 R1 flasher relay
2003 R1 flasher relay, how can i check it works, cant seem to get the indicators working, but if i put live wire to them they light up
Thank's, Joe
I don't stalk people
ko_racer
| posted on 13/11/08 at 09:42 AM |
How is it wired up? Live in, Live out going to input of indicator switch?
CRAIGR
| posted on 13/11/08 at 11:05 AM |
Believe the 2003 r1 flasher unit is only rated for 10watt bulbs so if you have 21watt standard bulbs all round it doesn't work. Try taking
either a front or rear bulb out and see what happens. On mine i ended up using an earlier flasher unit from a 1999 i think which looks identical but
is rated for 21 watt bulbs.
TimC
| posted on 13/11/08 at 11:50 AM |
I think one possible solution is to use the 5JJ flasher relay - I think I still have a spare if you want it.
CRAIGR
| posted on 13/11/08 at 01:48 PM |
Hi Tim
It was you that mine came from quote: Originally posted by TimC
TimC
| posted on 13/11/08 at 01:57 PM |
Yes it was - and I think I still have a spare if Joe needs one!
welderman
| posted on 13/11/08 at 04:26 PM |
Tim will give it a try if you dont mind, Ta
Joe
Thank's, Joe
welderman
| posted on 15/11/08 at 09:02 PM |
sorted it now fellas, im now using the 10w relay. and just got a small resistor from MAC 1, FOC, thanks Mark, as the savage light comes on, apparently
power coming baack up the wires.
Job for next week.
Thanks again for comments fellas
Thank's, Joe
