Author: Subject: 5pw wiring fault
Pdlewis
posted on 16/11/08 at 05:11 PM Reply With Quote
5pw wiring fault
Got my engine back in today and i have a fault code 11 which is the cam sensor. I think this may be a fault with the wiring.
Could someone tell me how many Volts should be passing through the blue wire and the white and black wire without the engine running
Build Photo Album
Updated 05/02/2009
jimgiblett
posted on 16/11/08 at 05:29 PM Reply With Quote
from the manual....."This code number appears if the condition continued for 10 seconds in which the starter motor does not run even if the starter switch has been pressed."
An example could be that the side stand switch has not been closed.
If the engine starts up and still gives this code then check the sensor.
- Jim
[Edited on 16/11/08 by jimgiblett]
