Author: Subject: Electrical Connectors
yellow melos
posted on 17/11/08 at 09:27 PM Reply With Quote
does anyone know where i can get electrical connectors that fit these kind of conenctors ???
[Edited on 17/11/08 by yellow melos]
irvined
posted on 17/11/08 at 09:30 PM Reply With Quote
They are called a mini-timer connector, you can get them from premier wiring, and also from trigger wheels (I'm sure you can get them elsewhere too) and cost a couple of pounds.
HTH
http://irvined.blogspot.com
Ben_Copeland
Off a vauxhall...
Look like cream vauxhall injectors.
Unless your after "new" ones, in which case.. no bloody idea
Ben
Locost Map on Google Maps
Enter Your Details Here
clairetoo
posted on 17/11/08 at 09:34 PM Reply With Quote
I get mine from work (but VWP sell the rubber boot's)
Its cuz I is blond , innit
Claire xx
Will weld for food......
martyn_16v
posted on 17/11/08 at 09:39 PM Reply With Quote
Junior power timer connectors. If you're happy robbing them from the scrappy then they'll be on pretty much any european car from the last 25 years.
yellow melos
posted on 18/11/08 at 01:27 PM Reply With Quote
Cheers Peeps,
The connectors i am told are normally found on BOSCH components, the Injector in the picture was just for illistration, i actually need them for Thermo time switch, fuel heater and .. somthing else that i cannot think of !!!
Thanks again
