mad4x4
| posted on 22/1/04 at 09:14 PM |
Dizzy driving me Dizzy
XR2 (ford 1.6CVH engine) the dizzy has built in map thing and three pins, What do I connect the three pins to ?
Scot's do it better in Kilts.
ady8077
| posted on 22/1/04 at 09:20 PM |
Hi
Sounds like the pick up for the ignition mod ?
Is it electronic ignition? If so have you got a haynes manual it should show the connections
Hope this helps
Adrian
Avoneer
| posted on 22/1/04 at 09:35 PM |
Is it a bosh dizzy?
Mine on my Pinto has three pins in a big plug. One to coil, one to ignition module and one to earth. Don't know if that's the same on the
CVH, but you might find that piece of useless information useful?
Pat...
mad4x4
| posted on 23/1/04 at 03:04 PM |
Yeh I have a haynes but it for my doner (1.8 Sierra) and not the engine I have now (1.6XR2-Fiesta).
Yes it is the dizzy with the electronic bit on it as one person said 1 for coil 1 for ignition and one earth but which is which?
Avoneer
| posted on 23/1/04 at 04:51 PM |
What colours are the three wires?
Mine were:
Orange - Goes to ignition module.
Purple - Goes to ignition module.
Black - Goes to earth.
Sorry, none go to the coil - that connects to different wires from the ignition module (small black box).
Does that help?
Pat...
Rob Lane
| posted on 24/1/04 at 09:37 AM |
Is it this one.
If so it's as follows:-
Distributor : Ford Fiesta 1989 / Escort 1300 1988 – Bosch 12 volt Electronic.
To fit twin webers a Side entry cap from Fiat Strada 85 Super -- Halfords Part HDC 515 -- Common Part XD134 is required.
Wiring connections (Numbers are in small print on connection plug):-
1 = Brown = Neg side of coil
2 = Blue = Earth
3 = Yellow = + 12 volt supply
Rob Lane
Avoneer
| posted on 24/1/04 at 05:44 PM |
And this is very different to mine!
Pat...
| posted on 24/1/04 at 06:08 PM |
CVH engine drives off the camshaft via a slot doesn't it, no skew gear on it? Sounds like you need the module from the 1.6 cvh as well. My mk4
Escort used the same one.
yours, Pete.
Rob Lane
| posted on 26/1/04 at 08:36 AM |
Sorry, I completely missed the CVH reference.
Reading too fast I suppose.
The image is for the Valencia / xflow
Rob Lane
mad4x4
| posted on 10/2/04 at 06:31 PM |
Sorted
This is how to do it, there are three wires ,
Brown -Earth
Green - side of Coil Before Suppressor
Black - 12v Ign Live .
If you break power to this wire usually to imobilise the vehicle ( ALRAM tip).
Found all this out from my mates fiesta which has just been converted to Injection ( Old dizzy wires were still there)
have a look at
http://www.xr2zetec.co.uk
