Author: Subject: Sealed lamp unit
wydraz
posted on 2/12/08 at 10:46 PM Reply With Quote
Sealed lamp unit
Guys,
I don't know where to get a replacement sealed lamp unit for my MK Indy!
Details from lamp which has blown (passenger side in a Right Hand Drive car):
From front of light:
Wagner
E11
7603
DRIVE
LEFT
From rear of light:
WAGNER
12.8V
7014
60/45W
A3
PILOT
TW4
W5W
U16
113
It also has a clear circle under the main light connector for, I guess, the separate sidelight to shine through.
Thanks,
Dan
[Edited on 2/12/08 by wydraz]
Howlor
posted on 2/12/08 at 11:15 PM Reply With Quote
If you can then post a pic and I am sure someone will help you out.
locoboy
posted on 2/12/08 at 11:53 PM Reply With Quote
yes..........
my local tip.
i threw 2 out last weekend.
I advertised them on here months ago free to a good home and there were no takers and i had a clear out last weekend.
I even thought it might be worth one last go before i ditch them.
bugger!
Locoboy
Mr Whippy
posted on 3/12/08 at 08:38 AM Reply With Quote
I love sealed beams, just got some for the beetle
measure the diameter as they are all universal fittings, you could get some from a Landy parts supplier or a vw one depending on the size of your lamp
posted on 3/12/08 at 09:55 AM Reply With Quote
I have 2 off, a Land Rover, 7 inch bowls so more or less standard for all brit cars of the 60s and 70s and also lotus 7 style lamps.
I think they have the circle for the side lamp too.
free to a good home.
posted on 3/12/08 at 10:36 AM Reply With Quote
Vehicle Wiring Products and Premier Wiring supply them for reasonable money.
wydraz
posted on 3/12/08 at 03:04 PM Reply With Quote
I'll take them, can you email me at rowlandsdaniel@hotmail.com? Cheers!
stevebubs
posted on 3/12/08 at 04:50 PM Reply With Quote
minispares keep them for reasonable money
Local Halfrauds also had 7" ones...not quite so cheap though...
posted on 3/12/08 at 07:33 PM Reply With Quote
Might be worth checking out a halogen conversion, made a huge difference to my old Mini and possibly cheaper than a pair of sealed beam units if you shop around?
wydraz
posted on 4/12/08 at 09:39 AM Reply With Quote
Halogen conversion
Will these work?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220303278311&ssPageName=ADME:B:EOIBSA:UK:11
I hope so as I bought them!
posted on 4/12/08 at 10:42 AM Reply With Quote
There's no mention of side lights in those is there? You will have to wire some separate ones in, no problem apart from finding some you like the look of and where to put them.
posted on 4/12/08 at 07:28 PM Reply With Quote
I find them a bit wobbly to make a really effective paperweight or door stop...
posted on 4/12/08 at 08:10 PM Reply With Quote
Ad says they are suitable for a Mini so they should have the sidelight
wydraz
posted on 4/12/08 at 08:42 PM Reply With Quote
I hope so - will let you know
posted on 4/12/08 at 10:42 PM Reply With Quote
The Mini Clubman (the proper one, not the pretender) had separate sidelights...
cjtheman
posted on 5/12/08 at 07:29 AM Reply With Quote
will check tonight if still needed i did have a pair but got the halogen replacements
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
Steve @ sVc
posted on 5/12/08 at 02:11 PM Reply With Quote
Wagner ones are made in the USA and are stocked by many uk suppliers including us @ sVc
Upgrading to H4 halogen is by far the best option, many suppliers have a budget type - our is £19 per pair inc bulbs & Vat, BUT, if you have the freestanding headlights with the rim split at the base and tightened with a bolt at the base of the rim, they are not the easiest fit without a bit of metal cutting / filing.
We do have ones that fit straight in without any modification at all.
regards Steve @ sVc
wydraz
posted on 5/12/08 at 07:22 PM Reply With Quote
Steve,
Can you please email me exactly what I need as I do have the ones which clamp at the bottom.
Dan
Steve @ sVc
posted on 8/12/08 at 04:29 PM Reply With Quote
Hi Dan - have sent a long and boring email
Regards
Steve @ sVc
wydraz
posted on 8/12/08 at 08:34 PM Reply With Quote
Yep the land rover ones are wrong
Cheers Steve will take a look at your email
