locoboy
| posted on 9/12/08 at 09:18 AM |
starting landrovers!
guys,
Im trying to turn over a discovery that we have had in at work.
Its got no keys and we have had the back off the barrell and still no life.
I have shorted across the 2 big terminals on the starter solonoid and it makes the starter 'whizz' but it does not engage.
Do i need +12v at the small spade terminal connectiopn aswell?
Is that an ignitipon switched live that allows the starter to engage?
Col
Locoboy
Mr Whippy
| posted on 9/12/08 at 09:25 AM |
you only need a 12 supply to the spade terminal, that is the solenoid and it does the high current switching, it also moves the pinion
forward and doing what you are, your just bypassing that so it will not engage and the starter just spins away without turning the engine
[Edited on 9/12/08 by Mr Whippy]
Richard Quinn
| posted on 9/12/08 at 12:15 PM |
Are you sure?
Mr Whippy
| posted on 9/12/08 at 01:16 PM |
Are you sure?
yes, off course I'm assuming he's just hot wiring it and has the other terminals already connected...if not it's well funny
| posted on 9/12/08 at 01:39 PM |
quote: Originally posted by Richard QuinnAre you sure?
The Whippy one is totally correct. Use a screwdriver to connect from the battery side of the solenoid (the high current connection) to the spade
terminal. This will engage the starter just as if you were turning the key.
[Edited on 9/12/08 by MikeRJ]
Richard Quinn
| posted on 9/12/08 at 03:45 PM |
It was a tongue in cheek reposte about the somewhat agricultural traits of some of the Landrover lineage! I didn't realise they had progressed
past the inertia type starter.
jambojeef
| posted on 9/12/08 at 04:00 PM |
My disco did something similar to this - refusing to start with the key after wet weather.
Ignition came on but no starter.
In the end I ran a new piece of wire frm the starter relay (passenger side kick panel) through the bulkhead and onto the starter solenoid.
Never failed since - until the cambelt broke!
Geoff
