Author: Subject: running megajolt 2d??
Danozeman
posted on 14/12/08 at 12:52 PM Reply With Quote
A question for megajolt users.
How do u get the megajolt to run 2d witht he newer config program?
It wont let me set all the load bins to 0.
Also has anyone got a good 2d map for a zetec,
[Edited on 14/12/08 by Danozeman]
Dan
BenTyreman
posted on 14/12/08 at 01:08 PM Reply With Quote
Can't you just enter the same advance for all loads for a single RPM bin?
Danozeman
posted on 14/12/08 at 01:10 PM Reply With Quote
thats what i have done at th minute. Is that how it should be done?
Dan
r1_pete
posted on 14/12/08 at 01:54 PM Reply With Quote
what engine / carb config are you using?
Werner Van Loock
posted on 14/12/08 at 07:23 PM Reply With Quote
Does it matter? Either way, you get the same advance for all load cells, so it's a 2D map in a 3D environment, just make sure your load cells are so that it doesn't keep jumping up and down, unnecessary stress for the MJ.
http://www.clubstylus.be
Danozeman
posted on 14/12/08 at 10:34 PM Reply With Quote
Its a 1.8 zetec with 2 litre cams and zx9r carbs.
Dan
paulf
posted on 15/12/08 at 09:03 PM Reply With Quote
Ive got a 3d one from my zetec with injection , you could just put the full load figures in all bins.
I will have to dig it out because its on my laptopat present but can find it tommorow.
Do you want a 2d because there is no throttle pot on the carbs?
Paul
Danozeman
posted on 17/12/08 at 12:54 PM Reply With Quote
No throttle pot at the minute. But there will be after sva.
Dan
