Author: Subject: push button start
Z20let Corsa
posted on 17/12/08 at 01:49 PM Reply With Quote
push button start
well i want a push button start. but is it worth of a sva test with this and how do i get on for security. its no good someone being able to jump in the car press a button and wee off with it. but theres no point in inserting the key into the ignition then pushing the starter button, i might aswell just use the key to start it then. what does everyone think??
locost +4 v8 in progress.
bbwales
posted on 17/12/08 at 01:52 PM Reply With Quote
I use the key for ignition as this is one of the security measures required by SVA, but I then have the push button start.
Regards
Bob
Z20let Corsa
posted on 17/12/08 at 01:53 PM Reply With Quote
Originally posted by bbwales
Regards
Bob
so its like key in and turn 1 click, then push the button??? kind of defeats the point of a push button start does it not??
bbwales
posted on 17/12/08 at 01:55 PM Reply With Quote
No i dont think so, how are you planning to switch on your ignition?
And as I said you still have the steering lock.
Mr Whippy
posted on 17/12/08 at 01:57 PM Reply With Quote
My buggy has a key for the steering lock but the starter button is live, shear lazyness on my part not to do it properly. Away, there’s been more than one occasion that I’ve driven off with the steering still locked, once in a filling station which could have been nasty
So do route the starter button power through the ignition key…
posted on 17/12/08 at 01:58 PM Reply With Quote
2 methods to immobilise: steering lock and battery cut out.
if you wanted to, you could remove wires from the igniton barrel so it is just the steering lock you use and have your push start.
not sure if that will make you happy as you will still need to insert key to undo lock.
or else find another method to immobilise the vehicle.
Z20let Corsa
posted on 17/12/08 at 02:03 PM Reply With Quote
i was origionally planning on having a switch for the fuel pump etc so i jump in, flick the switch and press the start button when the fuel pump had created the pressure. But like i say that means anyone can jump in and be away in it. which is no good. Just need to find a way of immobilising it. do i need a steering lock or just some way of immobilising the motor??
RoadkillUK
posted on 17/12/08 at 02:04 PM Reply With Quote
Ours is the same as above, turn the key to the 1st position to ulock the steering and ignition on, then you have the choice of turning the key more (or if there are impressional kids looking) push the button. It's a savage switch and lights up with the ignition on.
I've got one of those Maplin transponder imobilisers for christmas so I'm gonna have a look at that in the new year, see if I can bypass the ignition.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Scotty
posted on 17/12/08 at 02:17 PM Reply With Quote
Regards
Bob
same here, works a treat, and looks cool!
as others have ignition light running through starter switch so lights up with ignition but goes out when engine starts
might be childish but does it for me
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
smart51
posted on 17/12/08 at 02:40 PM Reply With Quote
The VX220 has a push button start and a key switch ignition. There is even a crank position on the key switch which is just not wired in.
Push button starts are fashonable bling. You might as well have the crank on the key, unless you particularly want a shiny red start button.
Guinness
posted on 17/12/08 at 02:49 PM Reply With Quote
A mate of mine had a Caterham R500 to which he'd fitted a proximity loop / transducer thingy in the drivers seat base. This operated a relay for the starter button.
Provided he had the transmitter fob in his pocket, he could just jump in and hit the starter button.
Was a well cool solution IMHO.
Mike
speedyxjs
posted on 17/12/08 at 02:50 PM Reply With Quote
Not sure if mr SVA will aprove but what about keyless entry system? If you could wire it to operate as click one on the ignition.
DarrenW
posted on 17/12/08 at 05:01 PM Reply With Quote
On mine i dont have steering lock or std key.
Immobilser, then key in and 1 turn, then push button start.
If you only want the push button then only option is to use the immobiliser that Mike refers to to switch the ignition on. After seeing Top Gear the other week id just be worried about the transponder range. You dont want it to work really until you are in (or almost in) the car.
flak monkey
posted on 17/12/08 at 05:07 PM Reply With Quote
I did that, works nicely
Sera
http://www.motosera.com
jollygreengiant
posted on 17/12/08 at 06:47 PM Reply With Quote
This is how I did it.linky to prior thread.
enjoy.
Mark G
posted on 17/12/08 at 07:15 PM Reply With Quote
I think I went a little over the top. I've got immobiliser fob on the dash, key which does steering lock and turns on the feed to fuel pump switch and ignition switches which are both on the dash next to the start switch.
