Author: Subject: wiring in the tunnel
cjtheman
posted on 1/1/09 at 04:24 PM Reply With Quote
hi all
any idea's on the best way to fit the loom into the tunnel i was looking at the self adhesive backing for cable ties do they do them you can drill on instead if sticking
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
posted on 1/1/09 at 04:26 PM Reply With Quote
Spiro wrap and split conduit then secured with P clips on mine. Rear loom uses connectors to keep it separate from the main bit.
Howlor
I protected the loom with a sleeve then p clipped and cable tied around the tubes. I would suggest you use something a little stronger than the adhesive mounts as it can be a hostile environment in the tunnel what with water oil etc. And if it breaks free the prop is sure to wipe out your wiring, and it is not easy to get in and replace.
[Edited on 1/1/09 by Howlor]
StevieB
posted on 1/1/09 at 04:38 PM Reply With Quote
I wrapped my loom in plenty of self amalgamating loom tape and fixed it with cable ties using the rivet on type of saddle from pole-volt.
twybrow
posted on 1/1/09 at 04:41 PM Reply With Quote
You could look at using trailer wire (ie the 7-15 core type). It keeps it all neat and easily understood, as each wire is numbered.
You can get cable ties with a small mounting hole to attach it with a bolt/self tapper/rivet. I think I bought mine from here....
tomgregory2000
posted on 1/1/09 at 04:58 PM Reply With Quote
How about these click me
you have to rivet, they will not accept stuck on pads
cjtheman
posted on 1/1/09 at 05:13 PM Reply With Quote
cheers guys
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
marshall
posted on 1/1/09 at 07:10 PM Reply With Quote
never use stick on cable tie fixings as the sva a man will not pass it use p clips best bet....
serieslandy
posted on 1/1/09 at 07:11 PM Reply With Quote
A better option, which I think has been mentioned on here before (in the link above) are "Screw fixing cable tie bases". You can cut the tie off and replace it and is also a permanent fixing.
posted on 1/1/09 at 08:16 PM Reply With Quote
I nearly failed my SVA 'cos the inspector thought I'd used stick-on pads everywhere - I had to demonstrate that I'd put a rivet through most of them. He let me use a couple of tie-wraps where I wasn't able to use rivets. I'd use convoluted tubing to cover the wiring, and P-clips to fix it safely.
Don't forget to keep the fuel pipe, electrics and brake pipes well spaced apart - none of them should be able to touch any of the others, even if pushed hard. Also, remember that there's a propshaft spinning in the middle of it all...
cjtheman
posted on 1/1/09 at 08:34 PM Reply With Quote
hi all i should have said that i did want to rivet them on but couldn't find where to get them from a trip to my local screw-fix in the morning
cheers for your input guys
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
