cloudy
| posted on 9/1/09 at 02:50 PM |
Multiway Compact Connectors?
These are a bit expensive:
http://www.cbsonline.co.uk/waterproof-multipin-wiring-connector-6-way-wpmul6-3483-p.asp
So I bought these:
http://www.cbsonline.co.uk/multipin-wiring-connectors-8-way-mul8-single-3402-p.asp
But they are HUGE! Do not look tidy at all, Does anyone have a preffered connector thats around the £2 a go mark?
Perhaps not an automotive one as they attract a premium it seems...
James
www.warnercars.com
Danozeman
| posted on 9/1/09 at 03:02 PM |
My ones the same as the first ones were about 3 quid each from durite.
Dan
tomgregory2000
| posted on 9/1/09 at 05:36 PM |
how many way do you need?
i have used the second one in your list but i also have 2 pairs of the first in your list, mine are 5 way but i didnt get on with them so cut them
off, you can have them if you want they just need new pins but they are only 5 way!
tommy
| posted on 9/1/09 at 06:54 PM |
You can buy the superseal connectors far more cheaply from
IEM Services. They do a lot of other
electrical stuff that seems well priced.
cloudy
| posted on 9/1/09 at 07:57 PM |
The IEM services ones are priced per half connector and ex VAT - works out same as CBS
[Edited on 9/1/09 by cloudy]
Meeerrrk
| posted on 9/1/09 at 08:40 PM |
i use the ones in the first pic, seem really good.
got them from ebay, this is who i used.
http://shop.ebay.co.uk/merchant/pdconnected
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
iank
| posted on 9/1/09 at 09:22 PM |
Farnell sell the superseal connectors as individual parts (socket, plug, pins, seals)
http://uk.farnell.com/jsp/search/browse.jsp?N=500006+1002292&Ntk=gensearch_001&Ntt=superseal&Ntx=
For the 6 way it works out at something like £3.53+VAT ea
if you buy 5 at a time.
The proper crimping tool is eye watering, but I doubt many people would buy one and would make do with pliers/cheap+nasty crimp tools.
Those big ones take full size spades by the looks of it, so would be rated at big amps.
Anonymous
cloudy
| posted on 9/1/09 at 10:03 PM |
http://www.asl-auto.co.uk/site/products_search.php?category=12&page=0
Really cheap, the parts in packs of ten - the rubber grommits are expensive though
James
www.warnercars.com
Meeerrrk
| posted on 9/1/09 at 10:25 PM |
yes, the price of the crimp tool is crazy, i tried a molex tool i have at work but it was just too small, so i just bit the bullet and tried using
long nose pliers and it worked out just fine. i did find a crimp tool on ebay for £20 + P&P but really isnt worth it when the pliers work.
Mark
| posted on 9/1/09 at 11:17 PM |
quote: Originally posted by cloudy
So I bought these:
those look like they use 4.7 mm spade so would be quite large.
for my dash, I used a 20 way PC connector from maplins; will try to find linky one their website loads up.
or have a look at VWP.
how many ways and what contact current rating?
| posted on 9/1/09 at 11:25 PM |
ATX motherboard connector
http://www.maplin.co.uk/Module.aspx?ModuleNo=44019
you need to buy the terminals separately;
YQUSTA
| posted on 11/1/09 at 08:24 AM |
I am looking at these
Polevolt
Download the PDF
they have alot of stuff and seam reasonably cheap need to add VAT but they do a mini connector.
YQUSTA
flibble
| posted on 11/1/09 at 12:44 PM |
http://www.vehicle-wiring-products.eu/VWP-onlinestore/connectors/multiconnectors.php
The Mate-N-Lock connectors are smaller and neater than your ones at the top, worked nicely for Saab loom.
[Edited on 11/1/09 by flibble]
bigfoot4616
| posted on 11/1/09 at 07:49 PM |
the mini connectors further down the page are even smaller, if its only for small cables
Johneturbo
| posted on 12/1/09 at 06:48 PM |
What about these rated @8 amps would that be ok for headlights?
http://www.autoelectricsupplies.co.uk/product/44
i tried the superseal ones before but found they never were seated correctly in the housing maybe due to not having correct crimp tool
[Edited on 12/1/09 by Johneturbo]
NS Dev
| posted on 15/1/09 at 09:59 AM |
yeah 8 amps should be ok (one per headlight I assume! ) those are "Sureseal" plugs, available from Farnell at a pretty good price I think,
decent plugs actually (which is a rare thing these days! )
