Author: Subject: Alarm
Northy
posted on 1/2/04 at 04:57 PM Reply With Quote
Alarm
Has anyone fitted an alarm to their car?
I've got an old one in the garage. Its designed to go off if someone opens a door, on if the internal movement sensors see any movement. I guess neither of these are of much use in a Seven
What I was thinking of doing was using the output for the LED to switch on or off the fuel pump relay, and a flashing LED. What do you think?
Could put the movement sensors in the bottom of the footwells I suppose?
Has anyone else fitted one?
Graham
andrew-theasby
posted on 1/2/04 at 07:43 PM Reply With Quote
Not really an answer to your question but have you seen the ones on ebay? Type in "remote start" and it should bring them up. About £70 and they have upto 4 channels to remotely operate lights, engine start etc aswell as alarm and immobiliser. Some even have paging facility. Not thatcham approved but gotta be better than nout.
Northy
posted on 1/2/04 at 08:22 PM Reply With Quote
Had a look, not bad.
But would you be able to remote start a car running Webbers?
Graham
andrew-theasby
posted on 1/2/04 at 08:53 PM Reply With Quote
Dont know really, never gave it a thought. Why do you think that you wouldnt e able to??
Northy
posted on 1/2/04 at 08:56 PM Reply With Quote
Don't you have to give the go pedal a couple of pumps, then start it, then give it gentle revs for a few seconds till it warms up?
No auto choke
Graham
andrew-theasby
posted on 1/2/04 at 09:07 PM Reply With Quote
I see, im not a good person to talk about starting engines cause mines still not run, but it would be cool as .... if it would work. Until the time you leave it in gear anyway!!
