Author: Subject: Halp multi meter readings
INDY BIRD
posted on 15/1/09 at 09:03 PM Reply With Quote
Hi
can anyone tell me what settings i need on a digital multi meter
to measure
6v
12v
to see if i have power
thanks all
blakep82
posted on 15/1/09 at 09:17 PM Reply With Quote
erm, voltage. assuming its for the car, then DC voltage, and it usually has different ranges, ie 2mV, 2, 20, 200 and you choose the right scale
________________________
iank
posted on 15/1/09 at 09:49 PM Reply With Quote
This one - it will read anything from 0 to 20.0v
From here
http://www.doctronics.co.uk/meter.htm
[Edited on 15/1/09 by iank]
Anonymous
INDY BIRD
posted on 15/1/09 at 10:54 PM Reply With Quote
Thanks all
never used one before
cheers
mad4x4
posted on 16/1/09 at 07:23 AM Reply With Quote
Quick point with these things.
if you get a - (minus) voltage the black lead is connect to the point that has the higher voltage than the red one ( so reverse the leads)
Usually you put the black lead on the CHASSIS and touch the red of the wire to be tested.
I find that the testers like this are more useful on the car....
LINKY
as they light up if there is 12v.
[Edited on 16/101/09 by mad4x4]
Scot's do it better in Kilts.
posted on 16/1/09 at 12:05 PM Reply With Quote
Remember to turn it off after use -- otherwise you get a flat battery (in the meter).
As you are new yo using one try it on a 1.5 volt battery first --- just don't expect to see 1.5 volts the voltage it shows wll be between about 1.2 volts and 1.58 volts depending on the condition of a battery. Across a car battery expect to see anything up to almost 15 volts if the the engine is running.
[Edited on 16/1/09 by britishtrident]
