Author: Subject: wiper wiring question I know. search.
RK
posted on 19/1/09 at 01:27 AM Reply With Quote
Nobody has answered this though:
Lucas wiper motor.
I have a 3 position switch - it isn't a column one and it isn't from a sierra or english car.
ON - Top position (normal)
OFF - Power (+)
ON - Bottom position (fast)
If I do as the S-V-C site suggests, and wire the Brown (park position) wire to the Normal position and the OFF (+) when the switch is OFF, won't this mean that the wipers will always be ON?
The Fused power (+) from the loom goes to the middle position on the back of the switch. If this is linked to the top position, the wipers will always be ON. Therefore, it appears I can't do this with my switch. If so, what do I need?
[Edited on 19/1/09 by RK]
t16turbotone
posted on 19/1/09 at 07:14 AM Reply With Quote
try this
http://www.geocities.com/sprite-midget/wipers.htm
posted on 19/1/09 at 10:33 AM Reply With Quote
Do as the SVC site says. The park function is switched by a cam on the wheel so that it is positive unless in the "park" position". The confusion is that people think of the "park" wire as a input when really it's an output!!!
Mr Whippy
posted on 19/1/09 at 11:36 AM Reply With Quote
I thought the park connection was a permanent live supply (from the ignition switch) to power the motor round to the park position once the dash wiper on/off switch had been switch off. Hence the minimum number of wires on a parking wiper motor is 3. All the switching is controlled inside the gear housing using copper tracks.
RK
posted on 19/1/09 at 01:48 PM Reply With Quote
So if the brown wire is just put to LIVE (+), it will self park? Why mention the Normal/slow position wire on the motor at all?
