jabbahutt
posted on 20/1/09 at 06:38 PM |
ford genuine speedo sender
Evening all
Been looking at the Burton power catalogue and found a Ford speedo sender part number REVFSS which when used with an adaptor can be used with a type
9
Has anyone used one of these? I'm thinking of this as an laternative to my set up which broke this weekend. Does anyone know how the Ford one
is wired? I need it to be one wired to the speedo and the other connection to earth.
Any info on these would be appreciated as looking at the price of trying to get a replacement sender this may actually work out better in the long run
as less chance of accidental damage.
Many thanks
Nigel
jonesier1
| posted on 20/1/09 at 06:55 PM |
speedo
i used the adapter and a ford speed sensor (3 wires) from a mondeo i broke for my zetec.3 wires, power,earth and supply to speedo.fits nice and
neat,better than messin with magnets
dave1888
| posted on 20/1/09 at 09:42 PM |
Thats the set up i used very neat and fits well in the tunnel.
| posted on 21/1/09 at 10:02 AM |
quote: Originally posted by jabbahutt
Evening all
I'm thinking of this as an laternative to my set up which broke this weekend. Does anyone know how the Ford one is wired? I need it to be one
Check you have enough space first to fit this - I have 4 speed box and one of the mounts would have been in the way so I ended up making my own
sender.
type 9 seems to be ok so I would recommend going this route - forget about replacement and silly magnets.
I will look in mondeo haynes to see if wiring is covered but I may forget.
jabbahutt
| posted on 21/1/09 at 11:01 AM |
cheers fellas
So if it has 3 wires, an earth, a postive 7 a wire to the gauge is there a way I could utilsie this?
Mine only has two one goes to earth and the other goes to the gauge. But I believe the gauge is sending the power to the switch and counting how many
times it earths rather than the power flowing through the sender to the gauge and it counting how many times it recieves power.
Any help appreciated as then I can get one ordered and sort it out so I'm back on the road.
Nigel
