Author: Subject: oil press light
RK
posted on 1/2/09 at 04:39 PM Reply With Quote
oil press light
Gauge is easy: 3 pins: one for gnd, one for sender, one for power.
How do I get a warning light to go on when there is low pressure/voltage? Searching has revealing absolutely nothing on this!
prawnabie
posted on 1/2/09 at 04:43 PM Reply With Quote
Id put a t-piece into the block and screw the sender and an seperate oil pressure switch into it. Run a wire from the switch to a light, and also a live to the light too.
Guinness
posted on 1/2/09 at 04:44 PM Reply With Quote
You need a separate sender. A switch rather than a variable one.
You can get them in different ratings / pressures to suit your engine.
Basically wire from live, through a fuse, through the lamp, to the pressure switch, to earth (dependant on type).
Mike
RK
posted on 1/2/09 at 04:48 PM Reply With Quote
But isn't the sender attached to the engine?
Guinness
posted on 1/2/09 at 05:27 PM Reply With Quote
Yup, the sender is attached to the engine, which hopefully will be attached to the chassis, via an earth strap.
My set up goes roughly as follows:-
Engine - taping in the main oil gallery - short length of flexible pipe - tpiece - oil pressure sender on one side - oil pressure switch on the other side.
Oil temp sender is in the sump to try to avoid heat soak from the block.
HTH
Mike
RK
posted on 1/2/09 at 05:34 PM Reply With Quote
Thanks very much, but for me those options are far too advanced.
I will go without one I think. I have the gauge already, so that'll do.
stevebubs
posted on 1/2/09 at 05:56 PM Reply With Quote
Oil pressure senders often have 2 terminals.
One goes to the gauge, the other is a switched earth for a low pressure light...
RK
posted on 1/2/09 at 05:58 PM Reply With Quote
Music to my ears Stevebubs!! Thank you very much everyone.
