Author: Subject: Megajolt wiring help
snapper
posted on 8/2/09 at 01:48 PM Reply With Quote
To try and solve some ignition problems i have embarked on wiring a complete plug and play Megajolt unit with EDIS, coil pack etc, literally a complete ignition system that will totaly replace the Megajolt already in the car.
I know that the Megajolt needs a 7.5 Amp fuse but does the EDIS need one? if so what Amp? and does the Fiesta Coil pack need a fuse? if so what Amps.
From the diagram attached where should the fuses go? Rescued attachment mjlj_v3_wiring diag pinto TPS.gif
I eat to survive
I drink to forget
posted on 8/2/09 at 02:18 PM Reply With Quote
15A fuse to EDIS and coil pack.
5A (or even 3A) fuse to the MJ itself.
(as recommended on the Megajolt site)
