givemethebighammer
| posted on 6/2/04 at 07:28 PM |
Dismantling old smiths gauges
I need to dismantle my old smiths gauges (dolomite vintage) to fit some leds inside for back lighting. Anyone know how to do this as non destructively
as possible. Took a look and wasn't entirely sure where to start.
chrisg
| posted on 6/2/04 at 07:52 PM |
Won't the LED's fit where the bulb goes? and come to that why not just use the bulbs?
I know I'm a nosey git!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
givemethebighammer
| posted on 6/2/04 at 08:20 PM |
The original buld holders are knackered. The green filters have all but melted away. I have tried to fit leds where the bulbs once fitted but they do
not produce light in the same way a bulb does (bulb = light in all directions, led = tends to be from the from of the led only). Thought if I mounted
a few inside the gauges I would a. get the required lighting and b. probably never have to change the leds (unlike bulbs).
[Edited on 6/2/04 by givemethebighammer]
paulf
| posted on 6/2/04 at 09:25 PM |
Look behind the rim and you will see a number of bent over tags securing it . Lever them up just slightly and you will then be able to rotate the rim
until it comes off. then remove the screws conecting the innards.
Paul.
givemethebighammer
| posted on 10/2/04 at 09:00 PM |
ta, just be careful not to break the clips (I didn't)
Steve @ sVc
| posted on 12/2/04 at 04:09 PM |
sVc tooled up for 2" bezels last year & we also buy in 3 1/2 & 4" ones.
Smiths tied to stop us!!
see www.s-v-c.co.uk
cheers
Steve @ sVc
givemethebighammer
| posted on 13/2/04 at 10:58 PM |
thanks Syd may take you up on the offer. But how have you got around he problem of the led light dispersion (or lack of it ?)
any photos in your archive ?
[Edited on 13/2/04 by givemethebighammer]
givemethebighammer
| posted on 14/2/04 at 09:48 PM |
Sounds good what do dimensions do you need ? presumably just the inside diameter of the hole where the bulb holder once went. Length of the rod would
not be an issue as there is nothing behind the gauges to foul on anyway.
