Author: Subject: Help - Earth to Gazza!
Gazza
posted on 6/2/04 at 08:38 PM Reply With Quote
I'm about to start fitting the wiring loom and was looking for advice on the best way to provide an earth connection....
Is drilling a hole in the chassis (Luego Velocity), fitting a rivnut and bolting the appropriately terminated wire to the rivnut / chassis - a good idea?
Just a bag o' rusty spanners
flyingkiwi
posted on 6/2/04 at 08:51 PM Reply With Quote
why not just self tapping screws? Seems to work on the escort ok.
It Runs!!!!! Bring on the SVA!
posted on 6/2/04 at 09:20 PM Reply With Quote
on mine, ive drilled thru and welded a bolt into the back, so that the thread protrudes. Might not be too clever if the chassis is painted or powdercoated though! works well though.
stephen_gusterson
posted on 6/2/04 at 10:50 PM Reply With Quote
i think a welded bolt is better than a rivnut
rivnuts can sometimes come loose or rotate in their hole which wont make good contact
atb
steve
[Edited on 6/2/04 by stephen_gusterson]
brianm
posted on 8/2/04 at 02:16 PM Reply With Quote
Weld a nut or bolt to the chassis, and take the engine earth strap and the battery negative to this nut or bolt
