Author: Subject: LED wing side/repeaters
jlparsons
posted on 15/2/09 at 01:44 PM Reply With Quote
Was thinking the other day... having sidelights on the wings might be useful safety-wise as they'd give a better impression of the width of the car at night. I could try converting a clear glass cycle wing repeater to do both jobs; 270 degree repeater and small forward facing sidelight, in the same casing using LEDs. Anyone know if Mr. IVA/SVA would have a problem with this?
Could do the same to the rear too, except that they'd be a tad small to use as main rear lights, so they'd have to be there in addition. Not sure what the law would say about that, though I'm guessing it'd be ok as it's not much different from the small spot-LED lights HGVs use to define their shape in the dark.
I've heard reports of homebrew side/fog/indicator lights getting through SVA/IVA as long as the brightness and angles are all within spec, but I've also heard of people failing on this. Anyone know what the official line is?
Wotcher thunk of the idea folks?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
snapper
posted on 15/2/09 at 04:03 PM Reply With Quote
As long as you have the correct number of compliant lights and reflectors then a few extra LED's should cause no problems what so ever
I eat to survive
I drink to forget
jlparsons
posted on 15/2/09 at 05:52 PM Reply With Quote
Good to know, thanks. I plan to use all in one units for my main lights so I guess that should be ok. Cheers!
