Alan M
posted on 15/3/09 at 07:45 PM |
Acewell speedo wiring
I've fitted an Acewell speedo to my locost and I am trying to wire it via a Sailes Marketing transducer which has 3 wires coming out of it,
labelled: yellow/green - signal; brown - positive; blue - earth. How do I connect it, as it seems to me that the Acewell has a red and a white wire to
go to a hall sensor???
big_wasa
| posted on 15/3/09 at 07:58 PM |
My understanding is with 3 wires it will be a hall sensor and with 2 wires it will be a vr sensor.
When ive played with an Acewell it was a Vr type set up with magnets to glue on for the sensor to read.
Alan M
| posted on 15/3/09 at 09:32 PM |
I just can't work out where to connect the 3 wires. How does a transducer work?
stevec
| posted on 16/3/09 at 08:23 AM |
As a general rule a 2 wire sensor will give you a ac signal and a 3 wire one will give you a 0 to 12v on/off square wave signal.
You should be able to use a pick up from a pushbike on a Acewell, I did.
Steve.
Alan M
posted on 17/3/09 at 08:17 PM |
I've sorted it. Sailles Marketing advised me that yellow & green wire gave out hall signal, so connected that to red wire from Acewell, then
the other 2 to earth. It works!
