Author: Subject: push button
blakep82
posted on 17/3/09 at 06:45 PM Reply With Quote
push button
got one of these from cbs
and i like lots
where can i get another on, in blue or green for example, without writing to use for a horn button or something?
looked on ebay, only seem to have a few in america for like £35
if cbs can sell them for £7.50, there much be some available somewhere else cheaper?
[Edited on 17/3/09 by blakep82]
________________________
posted on 17/3/09 at 06:48 PM Reply With Quote
I've just got one of those!
What really impresses me is the internal LED - up to 400v, AC or DC, either polarity. Neat trick...
blakep82
posted on 17/3/09 at 06:49 PM Reply With Quote
ah, well it says 400v, but look at the box it comes in! it says 12v
i think the actual switch itself can go to 400v, but the led may give up long before
Humbug
posted on 17/3/09 at 06:58 PM Reply With Quote
Looks smart - I could quite fancy one of those!
Do you need a relay to wire it in, or is it rated high enough already?
Also, do you get instructions on how/where to wire it into existing ignition circuit?
Simon
blakep82
posted on 17/3/09 at 07:01 PM Reply With Quote
nope. just comes in a box. thats it. work the wiring out yourself lol.
switch is rated at 16A, so will need a relay
omega 24 v6
posted on 17/3/09 at 07:06 PM Reply With Quote
Look for items made by Telemechanique i'm sure you'll get what your looking for. Try Neweyand aire's website under control and automation.
big_wasa
posted on 17/3/09 at 07:08 PM Reply With Quote
If it will switch 16A you will not need a relay.
I tested my zetec starter and the solenoide draws about 10A
rb968
I was just looking at that last night in the CBS catalogue! How do you mount it to the dash? How much sticks out? Bit different to the savage start button everyone has.
Rich
omega 24 v6
posted on 17/3/09 at 07:13 PM Reply With Quote
Or Rs components
here you go
rb968
posted on 17/3/09 at 07:19 PM Reply With Quote
Or CPC (Farnell I believe)
http://cpc.farnell.com/jsp/search/results.jsp?N=411+521+500001+1002730&Ntk=gensearch_003&Ntt=push+switch&Ntx=&isGoback=false&_requ estid=265812&isRedirect=true&_requestid=332096
Rich
blakep82
posted on 17/3/09 at 07:25 PM Reply With Quote
ah, i hadn't thought of RS. i did search the interweb for telemecanique (i didn't think it looked right, but thats how its spelled on the box lol)
i'll have to have a search through RS, seems you have to buy all the bits seperate though?
omega 24 v6
posted on 17/3/09 at 09:25 PM Reply With Quote
Perhaps yes. BUT if your switch was cheap enough from your source then you'd only need to change the front button part IIRC. So it could be a cheaper option. Do you have a Newey and aire outlet near you??
Location location location
location location location
Take your start switch in to the counter and see what others they've got in stock.
[Edited on 17/3/09 by omega 24 v6]
MakeEverything
posted on 17/3/09 at 10:11 PM Reply With Quote
Im going to put one of these on the passenger side......
Kindest Regards,
Richard.
blakep82
posted on 17/3/09 at 10:42 PM Reply With Quote
ah, cool, paisley's not too far away cheers for that! will give them a shot.
or, like you say, get another from cbs and then get a replacement button for the front, or just try and rub off the text on the front
