Author: Subject: Rear lights being vertical?
bassett
posted on 29/3/09 at 12:23 PM Reply With Quote
Hi, last week on my pre sva pictures a few chaps pointed out my rear fog light wasnt vertical which im hoping to sort today. But is this the only light that has to be vertical at the rear or must all of them be aswell?
Adam
mookaloid
posted on 29/3/09 at 12:27 PM Reply With Quote
Only the fog light needs to be vertical. I think it's so that it doesn't dazzle drivers behind.
Edit. I think the others still need to sensibly close to vertical too
[Edited on 29/3/09 by mookaloid]
omega 24 v6
posted on 29/3/09 at 12:31 PM Reply With Quote
Just the Fog IIRC
matt_claydon
posted on 29/3/09 at 06:06 PM Reply With Quote
Actually it's essentially so that it DOES dazzle the car behind (except it should only be on when it's foggy of course) - fog lights generally have a vertical beam focus of +/- 5 degrees, so if it's mounted on a slope then it won't shine brightly to the rear.
posted on 29/3/09 at 06:52 PM Reply With Quote
And don't get confused by tin-tops that appear to have their fogs at an angle (e.g. the new VW Beetle) - the lens may be on a slope but the reflector inside is vertical.
I think that the reason is actually a blend of matt's and mookaloid's ideas - if the fog is pointing upwards then it dazzles a driver following close behind, or shines over the driver behind if he's further away.
