Author: Subject: Temperature Gauges
prelude1980
posted on 11/4/09 at 12:11 PM Reply With Quote
Temperature Gauges
not sure if i should put this in here or in the engine section.
I have a ford temp sender linked to my megasquirt ECU that gives me 1 reading
An acewell sender linked to the acewell speedo that gives me another reading
They are both in the ford thermostat housing.
Before i tidied the wiring up a bit they both read the same or near enough but now they are nearly 10 - 15 degrees C difference.
any ideas?
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
omega0684
posted on 11/4/09 at 12:16 PM Reply With Quote
i had this problem with mine, you will find that the acewell sender and acewell dash are compatible and the acewell is programmed with the correct resistances of the acewell sender whereas this is not the case for the MS and the ford sendor, you need to use easytherm to recalibrate the MS so that the resistances of the ford sender have been put into the firmware of the ECU.
the reading you are getting from the acewell sender is a more reliable source for the correct temperature
alternatively you could purchase a temp sender that is compatible with MS from the seller of the MS
[Edited on 11/4/09 by omega0684]
prelude1980
posted on 11/4/09 at 12:46 PM Reply With Quote
thanks i'll try this and see what happens
gets you.
