vinny1275
| posted on 24/4/09 at 09:31 PM |
oops - fog light wiring wrong
Evening everyone....
Just fitted the rear fog light and I've ballsed it up somewhere - with the lights on, switch on the fog light, and the normal lights go dim
(including the instrument lights).
I used the MNR loom, but replaced the supplied switches for savage ones.
Anyone any idea where I've gone wrong? SVA on Tuesday......
ETA: The fuse for the fog is getting warm, so I think I must have managed to short it somewhere?
Vince
[Edited on 24/4/09 by vinny1275]
adithorp
| posted on 24/4/09 at 10:00 PM |
Could be a short but sounds like an earth fault.
http://jpsc.org.uk/forum/
blakep82
| posted on 24/4/09 at 10:05 PM |
i'll never understand how earth faults do what they do...
but i'd go with that also
________________________
| posted on 24/4/09 at 10:07 PM |
Do you have relays for the light circuits?
vinny1275
| posted on 25/4/09 at 07:21 AM |
Relays for dip / main beam, but not the fog. I've got a feeling it'll be the switch (as they're a bugg3r to wire where I've
put them...), I'll have a go at it today...
Vince
bitsilly
| posted on 25/4/09 at 09:20 AM |
Earth faults cause illogical havoc! I really would check them first.
I failed SVA on Fog light not working, I later found that I had it wired in plus to minus and vica versa. This wouldn't normally matter except
the bloody mounting screw went through the neg contact to help earthing, (thus my positive was connected to the chassis).
May be worth checking!
Another thing to try is disabling the hazards as a mistake there also causes havoc!
vinny1275
| posted on 25/4/09 at 10:29 AM |
Doh!
Earth fault = my fault!
Wired the switch in the same way as I did the Rad fan override - which has a relay! So, basically, when I latched the switch I was putting the feed
straight to earth - genius!
Troubleshooting wasn't helped by the fact that the bulb holder for the foglight wasn't making with the connector properly, so it took me
about 45 minutes to actually figure out what was going on - when I figured out my mistake and tested it, it still didn't work!
Doh.......
