james h
| posted on 25/4/09 at 10:37 AM |
Wiring Dominator headlights
Hi all,
Hopefully someone can help me...
I am up to the stage of wiring my dominator headlights (the small ones Russ Bost sells).
I don't seem to have a wiring diagram, so I don't know which wire is which.
Can someone who has used these headlights let me know which wire is for what?
Thanks,
James
[Edited on 25/4/09 by james h]
| posted on 25/4/09 at 02:24 PM |
Had the same problem, no diagram so I ended up wiring it wrong?
Obviously the two wires the sidelight bulb are easy to spot.
The two blacks are earths, thats were I went wrong!
Check my post about it HERE yuo should be able to identify the high a nd low
wires from that.
james h
| posted on 25/4/09 at 11:08 PM |
Thanks for that, I got it sorted in the end. The confusing thing was that there were four connections on the loom to the 5 on the light itself. I just
had to earth the main and the sidelights to the single earth wire on the loom.
