greggors84
| posted on 25/4/09 at 06:38 PM |
Indicator problems again
Had a previous problem with the indicators. Made a new earthing point and it seemed fine.
A few days later went to take the car out and the indicators werent working either through the stalks or through the hazard switch.
When I push the hazard switch it lights up but no indicator lights come on also the relay clicks.
If i take the relay out and put a live feed to the wire to the indicator stalks then push the lever up the right hand lights light up but if I push
down i get sparks from where im holding the other end of the wire which seems like a short somewhere in the left indicator wiring.
I dont know where to start looking for shorts really. Ive had a look round the column and stalks. The new earth I put in looks fine and that wouldnt
explain why it seems to be shorting through the left side and that shouldnt stop the right side from working.
I cant understand why it would fine one day then a couple later it stops working.
Have tried another flasher relay and its the same.
Chris
The Magnificent 7!
RichardK
| posted on 25/4/09 at 06:42 PM |
I've just changed my left stalk for exactly that sort of problem, fiddle with the hazard switch and I could get my indicators working. Seems to
quite a common fault.
Rich
Gallery updated 11/01/2011
