Staple balls
| posted on 25/2/04 at 09:15 PM |
simple diagram for pinto with premier loom
bit of a work in progress this, i've been slowly putting to together to make the wiring a little easier and i found the premier instructions a
little difficult to get my head around.
if anyone knows any of this to be wrong, or where wires should go (currently stumped by charge light from the loom should connect, same with oil
pressure/warning light)
(See bottom of thread)
[Edited on 27/2/04 by Staple balls]
| posted on 25/2/04 at 09:39 PM |
black/green on my 1.6 pinto goes from the module to the starter wire in the ignition barrel, to tell the module that the engine is cranking. i think!
is the black one the normal 'running' live?
Staple balls
| posted on 25/2/04 at 09:43 PM |
i honestly have no idea. at all.
i don't speak wiring
Staple balls
| posted on 25/2/04 at 11:17 PM |
oops
just twigged, going my the other diagrams i have about.
black/green to blue/black (ign switch to starter solenoid) ?
| posted on 25/2/04 at 11:28 PM |
think so! connected mine up like that the other day and it runs ok, cept no vacuum advance on it yet...
Staple balls
| posted on 25/2/04 at 11:29 PM |
yay
good enough for me
Staple balls
| posted on 27/2/04 at 09:47 AM |
excuse the bump
finally got it wired up and working (apart from the lights mentioned at the top)
so, have a nice new revision of the diagram in shiny pdf flavour (16k)
clicky
hope this helps someone
