mkindyblade929
posted on 28/4/09 at 09:42 PM |
Electric problems anyone help!!!!
I have a Mk Indy with Honda Fireblade 929 engine in it. ive had it for about 12 months everything has been fine until last week.
The car runs fine when in neutral all electrics work (lights, fan, indicators) the minute i put it into gear and try putting lights on, indicate, fan
on it cuts out. Ive checked main earth from battery to engine thats fine, all fuses seem fine, cant see any breaks in wires...
Anyone had similar problems, any advice...
Steve Hignett
| posted on 28/4/09 at 09:52 PM |
There simply must be a short if it's "all of a sudden" started to happen.
What's more the error must be somewhere in the region of either the Sidestand bypass that you (or the builder) created or the clutch switch that
you (or the builder) created.
Welcome to the forum.
Mark G
| posted on 28/4/09 at 10:01 PM |
As above, if its only when in gear then i'd be looking to see how the neutral switch was wired in, Mine's just earthed to the chassis.
If it helps it should be the light green wire from the ECU.
