Dangle_kt
| posted on 6/5/09 at 07:42 PM |
Voltmeter Question
Dumb question alert!
If the needle on a voltmeter installed on the dash is not moving at all, even with the engine running, during starting or anything - does it mean the
voltmeter is broken or does it mean the altenator is dead and its a matter of time before the battery goes flat?
I think I'm right in thinking that if the battery is cranking the engine over, yet the meter still reads zero then the meter is goosed and the
altentator etc is good?
Rod Ends
| posted on 6/5/09 at 07:47 PM |
most likely a broken/loose connection to the voltmeter.
mookaloid
| posted on 6/5/09 at 07:50 PM |
First place I'd look too
Mark G
| posted on 6/5/09 at 09:03 PM |
The volt meter should read around 11-12v when nothing is on, 13-14v when engine running and around 8-10v when cranking.
| posted on 6/5/09 at 09:17 PM |
A cheap and cheerful multimeter from Maplins is a kit builder's friend... somewhere around £5 will get you something good enough to trace
faults.
Dangle_kt
| posted on 6/5/09 at 09:34 PM |
cheers fellas!
