Author: Subject: Buzzing relay
greggors84
posted on 9/5/09 at 03:23 PM Reply With Quote
Buzzing relay
Still having trouble with my flasher relay. I had tried a spare relay I had but everything I checked seemed to be ok but the relay just clicked once instead of turning on and off.
Bought a new relay incase the other 2 were both broken. Now when I put the right indicator on it works fine but if I put the hazards on or the left indicator the relay buzzes.
I recently changed the main earthing point recently as I had a few fuses blow. Im guessing its an earthing issue as I havent actually changed anything on the car they just stopped working. But why would the right one work and the left one not.
If I put 12v to the wire on the stalks that connects to the left hand side lights they all light up so I dont think its a problem with the wiring going to the lights. I have un plugged them all and it makes no difference.
I have also tried 2 different indicator stalks and no difference.
Running out of ideas now!
Chris
The Magnificent 7!
