JamJah
| posted on 31/3/04 at 03:24 PM |
LED rings
Am I dreaming it or have i cracked up. I am sure I have seen some nice LED lights that have rings with more leds in.
Best way I think to describe em... Think of a porthole. Middle being one light. And the scres being a different one.
Do others a) know what I mean. and b) know where price or anything?
| posted on 31/3/04 at 03:32 PM |
You mean like these?
Look like this when lit:
They are available from >SVC<
[Edited on 31-3-04 by Hellfire]
JamJah
| posted on 31/3/04 at 03:36 PM |
Had looked on your pic arch but you odnt have those pics there!
Any other colours do you know? What applications can you use rings for?
alister667
| posted on 31/3/04 at 05:52 PM |
Hellfire,
They look fantastic, however I reckon you will need some kind of plinth behind them to ensure the faces of the lights are vertical for our friends at
the SVA.
Maybe it's just the angle I'm looking at the picture?
All the best
Ali
http://members.lycos.co.uk/alister667/
| posted on 1/4/04 at 07:30 AM |
We're hoping NOT. There is a tolerance in the SVA manual which allows the lights to be mounted out of vertical. I can't remember what the
limits are in degrees but have seen other cars which have passed SVA with similar size lights mounted in the same position as ours. IIRC, only fog
light has to be truly vertical.
| posted on 1/4/04 at 07:50 AM |
As it happens, I was looking at the new SVA manual this morning, on the train...
The ONLY light that has to be vertical and square is the fog light, for the perfectly good reason that it's a bright red searchlight!
The only requirement on other lights is visibility from various angles.
cheers,
locoboy
| posted on 1/4/04 at 12:06 PM |
you say sqare fog light Dave, i have seen plenty thet passed with round ones, or is that a change that relates to the new manual?
Locoboy
wicket
| posted on 1/4/04 at 01:08 PM |
Col
I think David means angular position not shape of the light when he says 'vertical & square'.
| posted on 1/4/04 at 02:02 PM |
Col,
what he said!
I meant "square" as in "90 degrees to the ground".
Ambiguous language, English...
locoboy
| posted on 1/4/04 at 02:37 PM |
i shall shut the fcuk up and get back to work then
Locoboy
| posted on 1/4/04 at 02:59 PM |
ROFLMAO
alister667
| posted on 1/4/04 at 05:16 PM |
Heheheh.
I check the SVA manual, and right enough I can't see any reference to the tail ights (other than the fog, as you say) being vertical.
Another one of my imagined regulations!
All the best,
Ali
