Bumble
| posted on 17/3/10 at 11:46 AM |
What size battery cable.........
Hi all.....done a search and found varying opinions on battery cable size. What size do you recommend for use with a Zetec?
Ta,
Matt
eddie99
| posted on 17/3/10 at 11:48 AM |
For which bit? Battery to Starter?
Edit: Battery to starter - 16mm
Starter - Alternator 10mm
Battery negative to fuse 16mm
Thats what i use anyway
[Edited on 17/3/10 by eddie99]
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
flak monkey
| posted on 17/3/10 at 01:15 PM |
I use 16mm extra flexible cable for the main neg and positive cables.
Sera
http://www.motosera.com
MakeEverything
| posted on 17/3/10 at 01:44 PM |
Otherwise known as Tri-Rated.
Any electrical wholesaler will sell it. Get it from them, it will be cheaper than Halfrauds or T'internet.
Kindest Regards,
Richard.
MakeEverything
Kindest Regards,
Richard.
| posted on 17/3/10 at 02:03 PM |
"Battery negative to fuse" ?
Normally battery negative should go straight chassis & engine earth points can be via a master switch if required.
If a main "Mega Fuse" (usually 100 to 200 amps) is used it is normally placed in the main +ve battery feed to the main engine
compartment fuse box.
Main starter solenoid cable is normally wired straight to battery +ve terminal without any fuse.
On modern tintops usual practice is to wire the main alternator output to engine fuse box side of the main Megafuse.
eddie99
| posted on 17/3/10 at 02:19 PM |
This is what i do:
  Wiring Loom Kit
eddie99
| posted on 17/3/10 at 03:13 PM |
With regards to the why do i fuse it!!
You dont need to and most people dont, its a worst case protector. If something goes wrong, the fuse protects you from shorting the battery and
causing a fire.
Its an OEM method!
Staple balls
| posted on 28/5/10 at 02:58 PM |
This is what i do:
  Wiring Loom Kit
Just found this thread looking for battery cable stuff, and I'm confused.
Seems to me that most 16mm2 cable is rated to 110A.
Why do you have a 150A fuse in some 110A cable? Surely you'd be better off with a fuse rated lower than the cable?
