highspeeddirt
| posted on 7/5/04 at 05:37 PM |
Indicator problem
The car is just about finished and I have an MOT booked for Thursday but I'm having a problem with the indicators. When I switch them on without
the engine running they flash once then stay lit. If the engine is running they flash 3 or 4 times getting slower each time then stop. The hazards and
all the other lights are fine. The bulbs are 21w rear, 10w front, 5w side and the flasher unit says 2 x 21w + 5w. Do I need a different flasher unit
or is it likely to be an earth problem?
| posted on 7/5/04 at 05:44 PM |
id put some 21w bulbs in the front, thats what the donor had, and 2x21w+5w is what it says!
might not change anything, but worth a go for a quid. the wattage does affect the flash rate.
theconrodkid
i had that with mine,if you cant put bigger bulbs in the fronts try a pair of 5w bulbs hidden under the dash to give the extra load
who cares who wins
pass the pork pies
crbrlfrost
| posted on 7/5/04 at 05:59 PM |
Or perhaps a 12V 10Watt resistor. No twinkling christmas lights in the cockpit.
| posted on 7/5/04 at 07:13 PM |
Or use a 4 pin flasher unit thsat dosen't care about wattage.
(might also be an idea to check the battery for a dead cell and check the charging rate -- as I don't understand why they are slowing down when
flashing with the engine running)
If you get them flash ok the MOT shouldn't be a problem but SVA might be a different matter if the e markings are checked.
| posted on 7/5/04 at 09:14 PM |
I reckon your battery is flat and not charging correctly.
As BT says - use a 4 pin to be sure!
Use a different battery to check!
highspeeddirt
| posted on 8/5/04 at 04:01 AM |
I'd thought about the battery not charging but I use it straight after it's been conected to the Optimate which indicates it's OK,
and I've already checked the charging voltage on the car. I will stick a 21w bulb in first to see what result I get.
Cheers Steve
highspeeddirt
| posted on 8/5/04 at 01:12 PM |
Thanks for all the help, problem solved
I put a 21w bulb in place of the 10w and the indicators worked. I can't fit a 21w in and fit the cover so I replaced the 10w bulb. I've
now fitted a 3 pin electronic flasher unit and the flash perfectly, much better than any 2 pin flasher. So now it's MOT Thursday and SVA next
Monday.
Thanks again Steve
