scudderfish
| posted on 2/7/10 at 01:34 PM |
ETB 80mm tacho & Megasquirt
I'm trying to wire up my tacho with no joy. Going by this doc http://www.extraefi.co.uk/Drawings/PDF_Files/tacho_Wiring.pdf there seems to be a
wide range of 'suck it and see' fiddling with resistors. Has anyone got this working, and if so how? What values did you use? I believe
I have a signal feed from my MS as I also have my old coil based tacho. I plugged a relay in as documented and it buzzes away like a mad thing.
Needle didn't twitch though
Regards,
Dave
phoenix70
| posted on 2/7/10 at 02:03 PM |
I used this diagram to get mine working.
Linky
if you tacho was normal coil driven this will work.
BenTyreman
| posted on 2/7/10 at 02:04 PM |
My VDO electronic tacho works using this circuit.
Can't remember the exact values of resistor.
Also had it working using this circuit.
Link to manual
| posted on 2/7/10 at 02:14 PM |
quote: Originally posted by scudderfish
I plugged a relay in as documented and it buzzes away like a mad thing. Needle didn't twitch though
if you wired the coil (realy) as shown in the diagram to the EFI signal, this shows that you have a signal. As you rev the engin the buzzing speed
should increase.
Do you have the ground (0 V) connected to the rev counter?
If you take a big bolt, connect to 12 V and then run a single wire up and down the the thread connected to the tacho (causes rapid pulses) you should
see the needle move.
If not, then it is broke.
errr, hang on, just read the instrucitons - it is dealing with wiring 2 differnt types of tacho to the board.
what type do you have? is it low signal or high whcih takes signal from ignition coil.
[Edited on 2/7/10 by 02GF74]
Mal
| posted on 2/7/10 at 02:47 PM |
If non of the above suggestions work send an email to Phil at Extra EFI.
omega0684
| posted on 2/7/10 at 04:47 PM |
if you have an electronic input on the rev counter just connect it to pin 2 on the edis. That the rev counter output.
scudderfish
| posted on 3/7/10 at 12:03 PM |
Result! Ages ago I asked Phil what it was for and he said ignore it. Plugged it straight into my non-coil tacho with no resistors and it worked
fine. Thanks for all the suggestions guys
