Author: Subject: solving fast flash
bi22le
posted on 31/7/10 at 10:31 AM Reply With Quote
solving fast flash
I all.
My Striker flashes quick in left right or hazards so I want to slow it down.
I have got NO LEDs in the system and I have tried putting resistors in line and it does not solve the problem.
I was thinking of getting this:
http://cgi.ebay.co.uk/Fix-Flasher-Blinker-Indicator-12V-Electronic-LED-Relay-/190400939956?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item2c54c7 c7b4
Im not too sure if it will work because it is for LED and it may just blow when used with normal incandecent bulbs.
Any one used one? what should I use \ do?
biz
Please read my ring story:
MakeEverything
posted on 31/7/10 at 10:34 AM Reply With Quote
Check your earths on the lights and the relay connections. This isnt normal with all lamps in.
Kindest Regards,
Richard.
mark chandler
posted on 31/7/10 at 10:56 AM Reply With Quote
Putting resistors in line will not help, they need to go across the load.
You could try higher wattage bulbs.
Ivan
posted on 31/7/10 at 11:02 AM Reply With Quote
I would think flashing speed is directly dependant on load - the higher the load the faster the flash so it implies that your bulbs are either too high a Wattage or your wiring too small or you have other things cross connected into the circuit
ReMan
posted on 31/7/10 at 11:08 AM Reply With Quote
Your lamps may be too low wattage, either that or yoiur flasher unit wants replacing
mark chandler
posted on 31/7/10 at 11:24 AM Reply With Quote
Its th e reverse, higher the load, slower the flash, so when you lose a bulb the flashers increase in speed warning you.
Cars generally have 3 x 15watt bulbs + dash per side, bikes have 2 x 25watt bulbs + dash per side.
bi22le
posted on 31/7/10 at 11:27 AM Reply With Quote
Thanks for the replies but I am confused.
High Watt bulbs = slower flash (because its draining more current) is that correct?
What wattage bulbs should I use all round?
Ill check the earths aswell.
bi22le
posted on 31/7/10 at 11:28 AM Reply With Quote
/\ /\ Already been answered! Took me too long to type!! /\ /\
snapper
posted on 31/7/10 at 12:40 PM Reply With Quote
The flashed sequencer on eBay advertises any bulb any wattage correct flash timing
I eat to survive
I drink to forget
bi22le
posted on 31/7/10 at 03:03 PM Reply With Quote
that one is three times the cost of the one i was looking at, i want low cost!
blue2cv
posted on 31/7/10 at 04:18 PM Reply With Quote
Normal for indicators is 21 watt not 15
RazMan
posted on 31/7/10 at 07:13 PM Reply With Quote
Correct - conventional flasher units are designed for 2 x 21W + 1 x 5W = 47W each side. If you have any less than 47W then your flashing rate will be too fast.
[Edited on 31-7-10 by RazMan]
Raz
posted on 1/8/10 at 03:34 PM Reply With Quote
Have you used bike indicators on your car? They often have 10W bulbs in them, which will mess up the flash speed.
I struggled to find 21W bulbs to fit my bike indicators - until I went to a bike shop and bought 23W ones that were exactly the correct physical size. (23W instead of 21W made no noticeable difference).
bi22le
posted on 21/8/10 at 05:32 PM Reply With Quote
Time to check the bulbs me thinks.
Thanks alot for all of your help
Biz
bi22le
posted on 15/1/11 at 04:41 PM Reply With Quote
THIS POST IS FOR REFERENCE:
I checked my bulbs today.
I had 5W up front, 3W on sides and 21W at rear.
I changed the fronts to 23W and the speed is alot more sensible. The earlier post regarding 47W seems correct (I have 23 + 3 + 21= 47W)
Hope this helps and is of some use.
Biz
RazMan
posted on 15/1/11 at 05:25 PM Reply With Quote
Blimey! 5 months to check them? You must have really been thorough
Raz
