stevegough
posted on 2/8/10 at 07:41 AM |
mounting headlights on the wing stays
As the title says - that way, when you turn, the lights will light up where you are going! -
any reason why it can't be done?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Steve Lovelock
| posted on 2/8/10 at 07:45 AM |
Well it could be done but, as the wheels move up and down so would the lights. Surely that would leave the light beams all over the place? Also, is
it not advisable to minimise unsprung weight?
smart51
| posted on 2/8/10 at 07:53 AM |
The vibration wouldn't make your bulbs last for long either. I think there's some IVA rule about which beams can turn with the wheels and
which can't too.
Miks15
| posted on 2/8/10 at 08:07 AM |
How about mounting them in the usual place on a pivot, then a connecting rod between it and the wing stay,
Then you wont get the up down movement just the left and right
mangogrooveworkshop
| posted on 2/8/10 at 08:30 AM |
Citreon had that system years ago.
If the IVA had a silly rule like that it would make most unfaired motorcyles illegal.
When we are blatting in the lanes local to me we could do with such a system.
i was thinking of a bearing and a morse cable to bring the transiton movement to the contraption.
self leveling to comply with the hid requirements would be cool as well.
[Edited on 2-8-10 by mangogrooveworkshop]
James
| posted on 2/8/10 at 08:37 AM |
It's hard enough to stop wing stays snapping with just 500g of fibreblass on them... couple of kg of light and they've got no hope! So
you'll need to massively beef up the wing stay.
- Muhammad Ali
stevegough
| posted on 2/8/10 at 08:41 AM |
MMM.... interesting replies so far.....many drawbacks being pointed out, but.....keep 'em coming, guys (and gals!).
Luego Locost C20XE.
daviep
| posted on 2/8/10 at 03:14 PM |
I would have thought it was the other way round, surely the wheels don't actually move up and down unless you have really big bouncy tires,
it's the body which moves on the suspension but looks like the wheels are moving as we are moving with the body?
Davie
smart51
| posted on 2/8/10 at 03:21 PM |
quote: Originally posted by daviep
surely the wheels don't actually move up and down unless you have really big bouncy tires, it's the body which moves on the suspension but
No, you've got it the wrong way round. Roads are anything but smooth, even if they look OK. The wheels move up and down a lot over the ripples
and ridges in an otherwise good surface. The movement of the suspension tries to keep the body relatively still , floating at an average height above
the road.
[Edited on 2-8-2010 by smart51]
prawnabie
| posted on 2/8/10 at 04:23 PM |
I thought motorbikes took a MSVA or similar test?
[Edited on 2/8/10 by prawnabie]
JF
| posted on 2/8/10 at 04:30 PM |
Davie
If that was the case, then why would you use suspension all together? If the wheels wouldn't bounce then hard mounting them would be perfect.
The only situation in wich they kinda do that as far as I know are karts. Wich run on really smooth tracks. And I believe even them have some
suspension due to chassis twist.
Anyway I do like the idea of headlights turning with the wheels. Some modern cars use so called cornerlights. Foglights that go on when you turn to
illuminate the corner. And I know there are trikes (the classic beetle type) that use linkages to turn their (extra) lights with the steering.
Personally I'd like to try integrating daytime running lights into the front edges of the wings. Using led's like new audi's etc.
Using some sort of linkage to turn the lights sounds interesting too. But not sure I'd use a 1:1 linkage. I have a gut feeling it would work
better if the lights don't turn as sharp as the wheels.
And I wonder what mister IVA has to say about such ideas.
stevegough
| posted on 2/8/10 at 08:42 PM |
Thanks for the interesting discussion, guys - but as I'm a coward, I'm still going to mount them in the standard location even though I
like to be different (don't we all?)
I think the examiner will find enough flaws in my build (let alone the car's!!) without me manufacturing some extra ones in!!!
Cheers, Steve.
Luego Locost C20XE.
stevegough
| posted on 4/8/10 at 11:24 AM |
Oops! Page 166 of the IVA (may'09 update)......
3. All lamps and reflectors fitted to the vehicle must be fixed and not move by swivelling, deflecting or otherwise while the vehicle is in motion,
except for:
any lamp or reflector which by design can be deflected to the side with the movement of the front wheel or wheels of the vehicle when turned for the
purpose of steering the vehicle
a headlamp for adjustment or dipping of the beam.
Guess this means the government have cast their vote on this one!!!
Luego Locost C20XE.
