big_wasa
| posted on 20/8/10 at 11:06 PM |
Can you tell me .....
Can anyone tell me why the ecu in a manual Ford Mondeo not fitted with cruise contol needs to know the position of the clutch ie up or down ???
PSpirine
| posted on 20/8/10 at 11:11 PM |
Might not start unless clutch is pressed (I know new cars with button starts need clutch down to crank)?
MikeR
| posted on 20/8/10 at 11:12 PM |
at a guess ...
so it can figure out to cut the fuel on overrun / go into minimal fuel to keep the engine ticking over / the developers couldn't be bothered
having two versions of the ECU.
big_wasa
| posted on 20/8/10 at 11:18 PM |
quote: Originally posted by MikeR
at a guess ...
I had thougth of that but I think it does that by sensing speed against throttle position ?
big_wasa
| posted on 20/8/10 at 11:20 PM |
Nope it will start with or with out the signal (switch operated)
Madinventions
| posted on 21/8/10 at 01:02 AM |
From memory, the clutch position is sent to the ECU so it can do all sorts of wierd and wonderful things like impose a lower rev limit (in case you
miss a gear), and raise the idle speed to prepare to pull away - that sort of thing. I don't think it does anything too spectacular, but the
eec-v is a clever bit of kit and who really knows what goes on inside it?
Ed.
View my band website:
http://www.shadowlight.org.uk
redscamp
| posted on 21/8/10 at 03:12 AM |
I have a mk2 mondeo 2.0 with "owls" ecu
as far as i can tell the clutch switch does nothing.
i have driven the car with clutch switch shorted and open and cant notice any diffrence.
the presure switch for the power steering makes a very small diffrence to the tickover
(shorted for slower)
the aircon pressure switch does not seem to effect the tickover as far as i can tell.
there is a spur from the vehicle speed sensor/speedo wire going to the ecu,
I have not played with this yet.
I think clutch switch is wired to the ecu as standard regardless of ecu type or market (uk/usa) and the signal is needed or not.
big_wasa
| posted on 21/8/10 at 10:38 AM |
Ok a couple "more" hours on the web latter.
It would look like that it does have some kind of limit set at around 4k and that it retards the ignition a touch to make a smoother gear change.
On the the eec-iv and early v it wont give a dtc code but it it will on newer models.
So I can bin that function.
One of the functions of the ac presure switch is to so the ecu can turn the fan on at a slow speed. si it has air flow when at a standstill.
No Ac so I can bin that aswell.
I am working on a 1999 owl5, I am already running the 1997 owls in the 7.
I am trying to find all its connected functions. I am nearly finished. I just need to finish the charge system.
StrikerChris
| posted on 21/8/10 at 01:20 PM |
You want to try working out a 200sx ecu!door switches,boot,speedo,air temp,abs,aircon,brake lights,reverse light,fuel gauge,brake bias valve,on and on
and on,all ended up at the ecu!and only the speedo made it as far as the striker!
big_wasa
| posted on 21/8/10 at 03:58 PM |
No problem if I had it in front of me
