pekwah1
| posted on 30/8/10 at 09:22 PM |
Electronic Speedo Sender
Hi Guys,
Have been having a search around here but i'm just getting confused....
I have a type 9 5 speed in the car, and i know that i need an electronic speedo so that i can actually calibrate it, but i'm getting confused
with where i put the sender.
Do i use an adaptor on the gearbox, or will i need to fabricate some kind of bracket to put a sender on the diff? I'm using a racetech
electronic speedo if that makes any difference....
Any help appreciated!
Regard,s
andy
mangogrooveworkshop
| posted on 30/8/10 at 09:36 PM |
http://tiny.cc/qbfg5
with a couple of magnets on the prop.
[Edited on 30-8-10 by mangogrooveworkshop]
marcjagman
| posted on 30/8/10 at 09:49 PM |
I'm using racetech too and also wondered how to get signal to speedo. They sell the bits you need plus instruction for just under £37. Send them
an email, very helpful guys.
pekwah1
| posted on 30/8/10 at 09:50 PM |
so the best plan is just to use the magnets?
i just thought that sounded a bit too much like what i use on my mountain bike!
if that's what everyone does and it works, and is IVA friendly then that's good enough for me!
gavin174
| posted on 31/8/10 at 06:55 AM |
depending on your speedo you can buy an adapter that goes into the gearbox and replaces the speedo cable..
i think eddie99 has one for sale.
https://www.burtonpower.com/product_main.aspx?dets_product.aspx?PSet=97&sTxt=electonic%20speedo
Xtreme Kermit
| posted on 31/8/10 at 11:39 AM |
I've got an ETB speedo, and the transducer from Burton which goes onto the speedo output from the box.
You need an adaptor to turn the circlip mount into a threaded one.
This has work just fine and dandy for a couple of years now.
| posted on 31/8/10 at 02:15 PM |
you can buy the adaptor from burton pwer as emntioned.
due to lack of space and I suppose cost, I ended up making my own sensore - chopper wheel running in bearing in a house made from bits of aluminuim,
magnet and hall effect sensor to drive a RaceTech speedo.
damn - why can't you put attachements in this forum?
