omega0684
| posted on 21/10/10 at 11:18 PM |
two questions on electrics
i have 2 questions regarding wire amp ratings for teo item my coil pack and my alternator, both require a 12v switched supply but what wire current
rating do they need?
alternator is a denso style and its a ford gen 2 coil pack.
i was going to use 13A wire, would this be ok?
| posted on 22/10/10 at 06:42 AM |
13 Amp is probably ok for the coil pack, but definitely not for the alternator. Even the small alternators can source about 30 Amps.
cliftyhanger
| posted on 22/10/10 at 06:54 AM |
are you sure about the alternator "sourcing" 30A.
I know those little ones produce that sort of current, so need at least 40A cable to the battery, but to switch the alternator on uses much smaller
current. I used some very thin wire, probably 8A, without even thinking it may need a big supply. I think they only need a few amps, so 13A shoudl be
way over the top....
happy to be corrected of course
| posted on 22/10/10 at 07:34 AM |
If it's just for the ignition warning lamp or remote sense wire then 13 amp will will be more than adequate.
| posted on 22/10/10 at 07:52 AM |
quote: Originally posted by cliftyhanger
but to switch the alternator on uses much smaller current. I used some very thin wire, probably 8A, without even thinking it may need a big supply. I
think they only need a few amps, so 13A shoudl be way over the top....
few amps to excite an alternator???
1/2 amp is more than plenty, the little ignition warning bulb is rated at about 2 to 6 W max.
omega0684
| posted on 22/10/10 at 09:16 AM |
i have some 11 Amp wire, i'll use that!
cheers chaps, locostbuilders to the rescue again
