Author: Subject: Digital Gear Indicator
brookie
posted on 9/11/10 at 06:41 PM Reply With Quote
hi there as above all the 1 im looking at are saying only suitable bike that had digital clock
and what im wanting to findout is did the 919 honda fireblade come with digital clocks as i dont think they did
loggyboy
posted on 9/11/10 at 07:01 PM Reply With Quote
There are a few, they work by comparing wheel speed to revs, and by being programmed by the user can work on any bike or car really.
The 2 types are elec speedo (so just need to be wired to rev guage and speedo signals)
and manual speedo which require (a usally magnetic sensor) fed signal thats added on to give an electronic speed reading.
Datatool (amongst others) make one that ussually crops up on ebay for about £30
brookie
posted on 9/11/10 at 07:21 PM Reply With Quote
right would this one fit then dont want to buy one and not be any good
Datatool Digital Gear Indicator on eBay (end time 01-Dec-10 15:41:44 GMT)T
loggyboy
posted on 9/11/10 at 07:33 PM Reply With Quote
Providing your speedo isnt cable driven, that will be fine.
If its not an elec speedo and you have a cable drive one, youl need something like this;
Acumen DG8 Digital Gear Indicator & SPEEDO UPGRADE KIT on eBay (end time 01-Dec-10 14:23:45 GMT)
but im sure ive seen them cheaper, so shop around.
brookie
posted on 9/11/10 at 07:55 PM Reply With Quote
loggyboy tar for the info but does it make a diffrance i fitting the koso rxn1 that a digital clocks
loggyboy
posted on 9/11/10 at 08:16 PM Reply With Quote
If you have a signal for the speedo for the koso (or it comes with a sensor) then you can piggy back that signal, so you can just use an electronic version.
posted on 9/11/10 at 08:57 PM Reply With Quote
Options for a gear indicator on the Fireblade used to be fairly limited and the major contenders were the Datatool Digi and Acumen DG8 units (both developed by the same person BTW) We've tried both and couldn't get either of them to work properly on our first Blade engined Indy or our ZX12R. Sometimes they worked and sometimes they didn't and they were both slow and never really reliable.
There is a fairly new gear indicator on the market called the GIPro X-Type manufactured by HealTech Electronics Ltd. HealTech Electronics are IMO, the leading manufacturer for speedo calibration modules and gear indicators. If I was after a gear indicator for the Blade, HealTech would be my first and only choice.
Phil
brookie
posted on 10/11/10 at 05:56 PM Reply With Quote
well i just took a set off smiths clocks out and they run from a semsor from the back drive shaft so theyn were not cable driven so does will i b ok
brookie
posted on 10/11/10 at 05:58 PM Reply With Quote
u right i been in touch with them m8 they want £100 for one m8 not wanting to pay that if i can help it just traying to work out what 1 i can usr first
Phil
brookie
posted on 11/11/10 at 07:46 PM Reply With Quote
any one
Benzo
posted on 12/11/10 at 08:27 PM Reply With Quote
i used the GIPro on my busa, it was plug and play and worked like a dream! £100 well spent...
