steve m
| posted on 20/11/10 at 02:57 PM |
Wireing identification marks
I am in the process of tidying up my wireing, under the dash,
what can i use for to indentify each wire, as most of mine is either red or yellow
i was thinking along the lines of little numbers on each wire, but were can i get them ?
and what are they called !!
MkIndy7
| posted on 20/11/10 at 03:01 PM |
B&Q do stick on numbers in the Wireing Accessories section.
Other than that places like RS components do the permenant ones you slip on over the end of the wire before putting the terminal on the end or
connecting etc but are no good for retro-fitting.
Or a Dynamo type label printer can be good for identifying cables with a code to keep it short or a lable of what the wire actually is.
jacko
| posted on 20/11/10 at 03:07 PM |
I agree with the type from RS components that is what i used that way you can make a drawing / plan and you know where every wire goes /comes from
Jacko
Confused but excited.
| posted on 20/11/10 at 04:25 PM |
Electrical wholesalers stock cable marking systems that consist of as plastic holder with ten rolls of numbered adhesive tapes in; 0 - 9. I have used
them for years.
This in fact: http://www.drillspot.com/products/64571/3m_sdr-3_wire_marker_tape
Made by 3M and work well but for on a car you need to cover with a clear heat shrink sleeve to protect the tape from moisture. Oops no you don't
these new ones are polyester.
[Edited on 20/11/10 by Confused but excited.]
alexg1965
| posted on 20/11/10 at 04:38 PM |
Try these from AES
Link
Or these from VWP
Another link
The slide on ones might not fit over very big cables though such as those to and from the battery.
Alex
MakeEverything
| posted on 20/11/10 at 05:40 PM |
them for years.
This is what ive used, but wanted to use these;
Kindest Regards,
Richard.
